928 guys what the heck is this??? |
spare time toys |
Dec 11 2004, 04:32 PM
I needed a flywheel for a manual trans I ordered one from this place and this is what they sent. It doesnt look like any flywheel I ever saw. It does have the starter ring though. What the heck is this? (IMG:style_emoticons/default/confused24.gif)
spare time toys |
flip side
Mueller |
Dec 11 2004, 04:34 PM
you really need to a get a manual for a 928 (IMG:style_emoticons/default/smile.gif)
some 928s have basicly 1 flywheel, but it has 2 friction surfaces for the 2 clutches it uses... |
jwalters |
Dec 11 2004, 04:35 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
(IMG:style_emoticons/default/wink.gif) It is the right one if you have the dual friction plate set-up--if your 928 is an '86 or older that is it...
ws91420 |
Dec 11 2004, 04:36 PM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
I'm not a 928 person but dont they have a torque tube behind that that actually attachs to the trans at the rear wheels.
spare time toys |
Yea I know but how would this hook to the flywheel?
jwalters |
Dec 11 2004, 04:40 PM
QUOTE(spare time toys @ Dec 11 2004, 02:36 PM) Yea I know but how would this hook to the flywheel? (IMG:style_emoticons/default/biggrin.gif) Do like Mueller says--get the manual---928's are beasts to work on---bet you haven't changed the timing belt yet huh??? If not go ahead and order a water pump for it when you do--when that belt goes---so does ALL your valves... |
spare time toys |
Dec 11 2004, 04:47 PM
I was trying to get this figured with out bugging rick. Its one of the two flywheels he needs to make the adaptor to put the engine on the trans. It just doesnt look right with no center. I do now have a set of manuals for the 928 and 914.
ws91420 |
Dec 11 2004, 04:53 PM
I was looking at the bird board at parts and they list a rubber convertor center. Possible that is what's missing?
jwalters |
QUOTE(spare time toys @ Dec 11 2004, 02:47 PM) I was trying to get this figured with out bugging rick. Its one of the two flywheels he needs to make the adaptor to put the engine on the trans. It just doesnt look right with no center. I do now have a set of manuals for the 928 and 914. (IMG:style_emoticons/default/wink.gif) Yea, it is a bastard set-up, when all the parts are on the counter, then it will all make sense! Good luck!! (IMG:style_emoticons/default/beer.gif) |
jim912928 |
Dec 11 2004, 09:53 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Part number?.... if it has on it (928 116 033 22) that is the intermediate ring. One clutch plate goes on one side, the other clutch plate on the opposite..then the pressure plate attaches to the entire assembly.
The flywheel will start with numbers (928 102 .........) and then vary based on year/tranny type. 86+ went to a single clutch plate on the manual tranny's. |
spare time toys |
Dec 11 2004, 10:37 PM
Upon further review they sent the wrong part. I was checking for the pn when I noticed their inventory number is not the number I ordered. It should be 7140 not 6872 some one just grabbed the wrong part.. We will see monday if they will make it good.
rick 918-S |
Dec 11 2004, 10:51 PM
Hey nice rack! -Celette Group: Members Posts: 20,460 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Idiots! They sent the intermediate plate! (IMG:style_emoticons/default/ar15.gif)
neo914-6 |
Dec 12 2004, 02:19 AM
Lo-Fi Version | Time is now: 17th May 2024 - 02:50 PM |
