Grinding in to Reverse |
buckeye |
Aug 30 2013, 08:51 AM
Newbie Group: Members Posts: 2 Joined: 10-May 13 From: Boise ID Member No.: 15,854 Region Association: Pacific Northwest |
It's been a while since I've owned a 914 and I'm sorting out bugs on my latest. '71 w/ a 2.0 and side shift trans both freshly rebuilt (under 600 miles) and after driving around for a bit it grinds when putting it in reverse, is it a linkage issue, worn springs at the lever, or a clutch adjust matter?
Cap'n Krusty |
Aug 30 2013, 09:05 AM
Probably a clutch adjustment issue, as reverse isn't synchronized. How is the 1-2 shift? How about the free play in the clutch pedal. Should be a little less than an inch when you pull on the pedal.
The Cap'n |
IanS |
Aug 30 2013, 12:56 PM
Member Group: Members Posts: 83 Joined: 27-February 12 From: Edmond, Oklahoma Member No.: 14,190 Region Association: Southwest Region |
Here is a snippet from Dr. Evil's transmission info supplement (I think you can PM him for a copy of this 31 page PDF)
*Note: These diagnostic suggestions are all given with the expectation that there is adequate, clean 90w, GL5 oil in the gear box* Reverse gear grinds: Since reverse gear has absolutely no means of synchronization, having it grind when you are shifting into it is a sure sign that your clutch cable is too loose, or that some other force is causing the cable not to fully disengage the pressure plate from the clutch during shifting (clutch drag). This is a problem that needs to be addressed sooner rather than later. Things to consider if your reverse gear suddenly starts to grind: · Your cable is stretching and may be a about to break · Your clutch tube has broken free of its supports inside that center tunnel · Your throwout bearing arm bushing that goes between the fork and the ball pivot is badly worn, or gone. |
Dr Evil |
Aug 30 2013, 06:00 PM
Send me your transmission! Group: Members Posts: 23,000 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
(IMG:style_emoticons/default/thumb3d.gif)
Like I was right there (IMG:style_emoticons/default/smile.gif) |
buckeye |
Aug 30 2013, 06:07 PM
Alright, I'll check the cable as it's new and may be stretching. I know it has the small plastic cup in fork and ball pivot. I'll also inspect the clutch cable tube. Thanks everyone I really appreciate the pointers!
76-914 |
Aug 30 2013, 07:28 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
If the tubes spot weld is broken you can look down and see the clutch tube move. Just remove the 3 bolts holding the shifter in place then rotate the shifter base 90 degree, step on the clutch and watch. Or remove the tunnel access cover near the firewall and check there for movement.
Lo-Fi Version | Time is now: 22nd May 2024 - 03:11 AM |
