remove points plate from distributor?, brain fart |
r3dplanet |
Sep 1 2013, 12:18 AM
Senior Member Group: Members Posts: 679 Joined: 3-September 05 From: Portland, Oregon Member No.: 4,741 Region Association: None |
Maybe I'm having a stroke or something.
I'm rebuilding a distributor from a 1.8 liter engine for a Weber conversion project. I've done this before for the D-Jet model with trigger points and didn't have difficulty. But for whatever reason, I can't seem to yank out the two points plates as a unit. The top plate can be pulled, but not the bottom one. All of the screws are out. So am I just being dense here or am I missing something? Additionally, does anyone have any master genius plans on how to remove the metal circlip from the depths of the middle shaft? Thanks, Marcus |
euro911 |
Sep 1 2013, 01:05 AM
I think there's a pin you need to press out at the bottom of the shaft ... in the wobbly part that engages the slot in the dizzy drive gear
gifted914 |
Sep 1 2013, 01:18 AM
middleagecrisis Group: Members Posts: 30 Joined: 17-April 13 From: Australia / Brisbane Member No.: 15,778 Region Association: Australia and New Zealand |
I think there's a pin you need to press out at the bottom of the shaft ... in the wobbly part that engages the slot in the dizzy drive gear The lower plate clips in to aluminium casting inside the dizzy. Try turning the plate to disengage the lower plate. The circlip inside the cam, sometimes it will come out with a sudden force applied to it or use a bigger hammer Best of luck (IMG:style_emoticons/default/driving.gif) |
r3dplanet |
Sep 1 2013, 01:34 AM
Hey gang,
Right on both counts. If only I could have a stroke .. of genius! Distributor disassembled and soaking. Thanks! -marcus |
Lo-Fi Version | Time is now: 17th May 2024 - 04:11 PM |
