Taking the Tbars out..., Why wont the darn things go?? |
Andyrew |
Dec 12 2004, 12:01 AM
Since no one responded to my Rear Caliper Adjuster Screw Stuck Thread I figured I'd put in the new 22mm T bars.
Only problem is I cant get the darn things out.. Took the adjuster and other thing off.. Then The front thing off as according to the haynes... Then it said to pull or push it out... Wont freekin move (wiggles.. but thats it..) Is the front part (in relation to the car) like a dust cap thats suposed to come off? cus its not... How to's?? Thanks... Im running out of things to do waiting for dad to get home... garage is clean... lol... Andrew |
Aaron Cox |
Dec 12 2004, 12:03 AM
ive only pulled them after ive pulled the a arm.....
Andyrew |
Dec 12 2004, 12:09 AM
Dont see how it would make any diff.... theres no load on it...
How did you do it? BFH? |
Aaron Cox |
Dec 12 2004, 12:11 AM
pulled the adjusters.... got a rag, grabbed the torsion bar and pulled. what would you hit with a hammer? they only go in one way (IMG:style_emoticons/default/wacko.gif)
Andyrew |
Dec 12 2004, 12:13 AM
Thats what I thought...
They only go one way.. but they dont want to come out....????? got a glove.. pulled.. no go... Then I see pics with the front of it out.... ???? I thought I would just pull it out, but it didnt pull out any. |
Aaron Cox |
Dec 12 2004, 12:14 AM
the adjusters are out correct? so there is no load at all..... (IMG:style_emoticons/default/idea.gif)
you can pull the cap on the front of the a arm..and you can it them out with some sort of dowel. |
Andyrew |
Dec 12 2004, 12:30 AM
Dowel... hammer? I always hated when people used the word dowel.. I never quite understood it..
Yes the tensioner (whatever its called) is out. No tension... but I cant pull neither the T bar, nor the cap... hit the t bar with a hammer trying to persuade the cap off, no go (have other t bars, I'll trash these if there bad.) I see brads active... Wonder if he's got any thoughts?? Andrew |
Aaron Cox |
Dec 12 2004, 12:31 AM
there is a tech article on PP i think (IMG:style_emoticons/default/wacko.gif)
you have to drill the cap...then pull it IIRC. hitting the Tbar into the cap wasnt smart,....made your job harder (IMG:style_emoticons/default/wacko.gif) |
Andyrew |
Dec 12 2004, 12:45 AM
I looked for a PP article before I started.. Nada...
Then I looked in our tech articles... Nada... hanes manual was vauge.. my other 3 manuals were vuage as well... Drill into the cap.. Then pull? I dont see how that would do anything.. lol I'd rather hear from someone, or read something that says actually what to do... Not a IIRC... before I start drilling (IMG:style_emoticons/default/wink.gif) Thanks though! |
Aaron Cox |
Dec 12 2004, 12:53 AM
haynes 911 manual: drill a small pilot hole in the endcap of the housing. remove with a slide hammer. remove torsion bar. replace cap with new one or fill the hole.
IIRC this! :finger2: (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif) |
Mueller |
Dec 12 2004, 01:00 AM
QUOTE haynes 911 manual: drill a small pilot hole in the endcap of the housing. remove with a slide hammer. remove torsion bar. replace cap with new one or fill the hole. easier method, smack torsion bar with a BFH, it'll remove the cap and the torsion bar will slide out the front of the a-arm you can drill the cover, and insert a punch and try to push the torsion bar out towards the rear of the car...fill up the hole by welding it or with rtv got a dremel? cut a slot in the screw that is giving you trouble on your calipers, use a large standard screwdriver to remove the screw |
skline |
Dec 12 2004, 01:06 AM
I punched mine out with a hammer. It popped the cap off and came right out the front. It took a couple of hits but it worked.
Andyrew |
Dec 12 2004, 02:07 AM
I tried with my biggest hammer... No go...
Put some lube on the cap.. see how it is in the morn... Andrew |
jtf914 |
Dec 12 2004, 08:03 AM
Member Group: Members Posts: 428 Joined: 31-December 02 From: Burlington, CT Member No.: 58 Region Association: North East States |
QUOTE(Mueller @ Dec 12 2004, 02:00 AM) you can drill the cover, and insert a punch and try to push the torsion bar out towards the rear of the car...fill up the hole by welding it or with rtv (IMG:style_emoticons/default/agree.gif) That worked for me..... |
dan10101 |
Dec 12 2004, 04:20 PM
TORQUE-o-holic Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest |
We tried the big -=-- hammer again with more determination. Popped right out the front. (IMG:style_emoticons/default/smilie_pokal.gif)
On to the next side, should go a bit quicker... Thanks once again!! |
Lo-Fi Version | Time is now: 17th May 2024 - 02:38 PM |
