Exhaust Smoke Distributor Shaft Wear ? Help, 2.0L D-Jet Video content experts wanted |
thompson-mfr |
Sep 3 2013, 09:36 AM
Thompson, Ryan Group: Members Posts: 198 Joined: 30-September 08 From: Silverton, OR Member No.: 9,598 Region Association: Pacific Northwest |
Hi All,
Please see the video I took of my car and give your opinion. It is smoking on deceleration, in between shifts, and when I let off the gas. Nothing at idle. It started doing this all the sudden???? And maybe a separate issue: When I push on the distributor (towards the passenger compartment) the idle acts normal. When I pull on the distributor the idle goes way down. The reason I noticed this is the idle has been really low and I discovered this. Eventually it reverts back to a low idle. http://www.youtube.com/watch?v=LIvslHrr35A...eature=youtu.be |
76-914 |
Sep 3 2013, 10:23 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Are you saying the dizzy will move up and down (push-pull?) or it will move left to right? It shouldn't move at all. If up n down the retaining clamp is loose. Lifting or pushing it seems like it would change timing. Left/right movement isn't right either. I don't think a worn o-ring would allow lateral movement. Pull that thing and see why it is moving.
thompson-mfr |
Sep 3 2013, 04:46 PM
Are you saying the dizzy will move up and down (push-pull?) or it will move left to right? It shouldn't move at all. If up n down the retaining clamp is loose. Lifting or pushing it seems like it would change timing. Left/right movement isn't right either. I don't think a worn o-ring would allow lateral movement. Pull that thing and see why it is moving. Not up and down . It moves backwards and forwards. You don't really feel like you are moving it, but you notice the change in idle and running condition when you do push/pull. I will pull the distributor and take a pic. Anyone on the smoking problem? Watch video please. |
Kirmizi |
Sep 3 2013, 05:44 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
Your smoking problem sounds like rings to me. (IMG:style_emoticons/default/confused24.gif)
thompson-mfr |
Sep 5 2013, 01:46 PM
TheCabinetmaker |
Sep 5 2013, 05:10 PM
Smoking on decel, between shifts, is a symptom of worn valve guides.
thompson-mfr |
Sep 5 2013, 06:36 PM
pilothyer |
Sep 5 2013, 08:04 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Smoking on decel, between shifts, is a symptom of worn valve guides. If I have worn valve guides (assuming rings are good) my compression should be normal. Correct? Let me ask it another way valve guides will not affect compression correct? As long as the valves are sealing properly in their seats the worn guides should not cause any compression loss. |
Lo-Fi Version | Time is now: 20th May 2024 - 05:37 PM |
