A few underbelly pics of my LS1-powered car |
oldschool |
May 22 2014, 11:04 AM
Advanced Member Group: Members Posts: 3,362 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
Did anyone else figure out that Doug is Douglas Kott? The Road & Track guy who was such a 914 fan he wrote about it several times during his tenure at R&T? Not there any more, he left when they moved the office to Detroit. Great guy. He bought an airplane I think. And I have his 2.0 in my 914 (IMG:style_emoticons/default/shades.gif) |
Dr Evil |
May 24 2014, 06:30 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Interesting. I built the tranz in that car and the new owner contacted me to discuss the possibility of putting even more HP and TQ into it. I told him to ditch the 901.
Understand the torque is how much instant force is applied. Like a slow moving truck, it can pull a stump out at a slow pace. Resisting torque takes beefy gears, like the ones in a 930. The 901 gears are thin, this is fine for high RPM with low mass. Not so fine for torque when your beefy engine says "MOVE!" and your beefy tires say "GRIPPING!" and inertia says "HAHA FUCK YOU!" and you rip the thin teeth off of the gears. I never understand why people would not put money into an appropriate transmission to use ALL of the power available. However, I think that V8 conversions are not practical to begin with. Kind of like a hot rod rather than a performance vehicle unless done right with lots of money. |
messix |
May 24 2014, 08:01 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
Interesting. I built the tranz in that car and the new owner contacted me to discuss the possibility of putting even more HP and TQ into it. I told him to ditch the 901. Understand the torque is how much instant force is applied. Like a slow moving truck, it can pull a stump out at a slow pace. Resisting torque takes beefy gears, like the ones in a 930. The 901 gears are thin, this is fine for high RPM with low mass. Not so fine for torque when your beefy engine says "MOVE!" and your beefy tires say "GRIPPING!" and inertia says "HAHA FUCK YOU!" and you rip the thin teeth off of the gears. I never understand why people would not put money into an appropriate transmission to use ALL of the power available. However, I think that V8 conversions are not practical to begin with. Kind of like a hot rod rather than a performance vehicle unless done right with lots of money. mike I think another point of the weakness is the size of the input and output shafts and the distance of the supporting bearings through out the tranny. from the clutch into the tranny is one shaft that is only held in place by 2 bearings, and the distance between the two spans along the differential and the gear stack to the "intermediate plate" which is the last bearing that offers any support to the shaft. all the torque input is carried on this shaft and it is not of sufficient size to not twist and deflect [candy caning]. when this happens bearings and gears go bye bye. the next weakness would be the output shaft at the pinion gear and the ring gear. the pinion end could simply twist right off. the shaft size is small there also. I have sheared pinions with much larger shafts than on a 901. so the 901 will live when not abused with clutch dumping launches, burn outs, hard "speed shifts". |
partwerks |
May 24 2014, 08:21 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
I'm wondering if it is safe to use with the LS engine?
I've never popped the clutch, or smoked it's shoes, not sure about the hard shift thing? This is what mine currently has in it's internals: A 904 shaft with a C second gear and an LSD. Your box is very special. It does have the billet plate in it. After the change over, this is what is currently has in it: C-N-Z-fH. This setup will move all the gears higher for higher top speeds and lower RPM |
Lo-Fi Version | Time is now: 1st June 2024 - 05:12 PM |
