914/6 Rear Shock Assembly, Bump Stop |
stuartgto |
Sep 3 2013, 10:29 PM
Newbie Group: Members Posts: 15 Joined: 17-April 13 From: 94070 Member No.: 15,777 Region Association: None |
I am trying to find the dimensions of 914.333.053.01, "Supplementary Spring" or bump stop for the rear shock assembly. The part is no longer available and trying to find one that fits between the cap and the spring plate is difficult. I purchased one from NAPA that is too big but I could remove material if I knew what the size should be.
http://www.pelicanparts.com/914/parts/Rear...r_shock_big.htm Thanks in advance |
Cap'n Krusty |
Sep 3 2013, 10:33 PM
Contact Bruce Stone here on the list and ask if he would measure one for you. I'm sure he has 'em.
The Cap'n |
shoguneagle |
Sep 4 2013, 05:38 AM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
as an alternate, I will be going into my rear suspension at the end of Sept and should be able to measure exactly what you need. I have original equipment except for aftermarket 140# springs. Just make sure I understand and we are looking at everything "with same set of eyes".
It is there if you need it. Steve |
Jeff Hail |
Sep 4 2013, 08:22 AM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
I am trying to find the dimensions of 914.333.053.01, "Supplementary Spring" or bump stop for the rear shock assembly. The part is no longer available and trying to find one that fits between the cap and the spring plate is difficult. I purchased one from NAPA that is too big but I could remove material if I knew what the size should be. http://www.pelicanparts.com/914/parts/Rear...r_shock_big.htm Thanks in advance Last I checked Paragon has the replacements. If correct they were meant for Koni's but should work with other shock makers. |
stuartgto |
Sep 4 2013, 01:18 PM
I am trying to find the dimensions of 914.333.053.01, "Supplementary Spring" or bump stop for the rear shock assembly. The part is no longer available and trying to find one that fits between the cap and the spring plate is difficult. I purchased one from NAPA that is too big but I could remove material if I knew what the size should be. http://www.pelicanparts.com/914/parts/Rear...r_shock_big.htm Thanks in advance Last I checked Paragon has the replacements. If correct they were meant for Koni's but should work with other shock makers. Thanks for the referral. Parts are on their way. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:01 PM |
