stuartgto
Sep 3 2013, 10:29 PM
I am trying to find the dimensions of 914.333.053.01, "Supplementary Spring" or bump stop for the rear shock assembly. The part is no longer available and trying to find one that fits between the cap and the spring plate is difficult. I purchased one from NAPA that is too big but I could remove material if I knew what the size should be.
http://www.pelicanparts.com/914/parts/Rear...r_shock_big.htmThanks in advance
Cap'n Krusty
Sep 3 2013, 10:33 PM
Contact Bruce Stone here on the list and ask if he would measure one for you. I'm sure he has 'em.
The Cap'n
shoguneagle
Sep 4 2013, 05:38 AM
as an alternate, I will be going into my rear suspension at the end of Sept and should be able to measure exactly what you need. I have original equipment except for aftermarket 140# springs. Just make sure I understand and we are looking at everything "with same set of eyes".
It is there if you need it.
Steve
Jeff Hail
Sep 4 2013, 08:22 AM
QUOTE(stuartgto @ Sep 3 2013, 09:29 PM)
Last I checked Paragon has the replacements. If correct they were meant for Koni's but should work with other shock makers.
stuartgto
Sep 4 2013, 01:18 PM
QUOTE(Jeff Hail @ Sep 4 2013, 07:22 AM)
Thanks for the referral. Parts are on their way.
