plugs for heads, EGR tubes |
qa1142 |
Dec 12 2004, 01:42 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
Anyone know what thread is on the tubes? I would like to just plug with set screws...
75 2.0L heads btw |
nebreitling |
Dec 12 2004, 01:46 PM
Member Emeritus Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
i don't know about the tubes themselves, but i capped my tubes with some caps i found in the plumbing section. NOT a standard pitch.
skline |
Dec 12 2004, 03:33 PM
Born to Drive Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
I think they were like .1.00 pitch. I went to the local flaps and got a bolt with the same thread for about .20 each and they fit perfectly. Holds the sheetmetal on also. Put your manifolds on after you put them in though. The manifold will sit right up against the head of the bolt to keep it from turning out.
Allan |
Dec 12 2004, 03:48 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
10mm, 1.0 pitch, 50mm long.
94teener |
Dec 12 2004, 07:07 PM
Member Group: Members Posts: 209 Joined: 6-February 04 From: Jacksonville, FL Member No.: 1,636 |
Your use 10mm valve adjusting screws are ideal for plugging those ports, cheap too.
Phil |
mattillac |
Dec 13 2004, 12:50 AM
robots! Group: Members Posts: 536 Joined: 27-October 04 From: vallejo,ca Member No.: 3,020 |
weld the top of the tubes shut. or if you can't weld, pinch the tube closed by pounding it with a hammer, nice and flat. (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif)
qa1142 |
Dec 13 2004, 08:23 AM
10M set screws are $5.03 a box from McMaster Carr, I just needed the size
Thanks Team! (IMG:style_emoticons/default/beerchug.gif) |
Cap'n Krusty |
Dec 13 2004, 12:36 PM
Just so you know, and the misinfo doesn't get spread, the EGR feeds into the aircleaner (intake), the tubes in the heads are for the air injection into the exhaust. They're 10x1mm, but the actual sealing surface is the ring on the injector tube itself. I've seen a lot of kludged plugs come out. The Cap'n
qa1142 |
Dec 13 2004, 04:45 PM
are you sure they are 10M 1.0? Mcmaster only has 10M 1.5
www.mcmaster.com 92029A435 Metric 316 SS Cup Point Socket Set Screw M10 Size, 40mm Length, 1.5mm Pitch |
Dr Evil |
Dec 13 2004, 04:54 PM
Send me your transmission! Group: Members Posts: 23,001 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
go to your VW shop and pick them up. They are for 2.0L TIV engines.
Lo-Fi Version | Time is now: 23rd May 2024 - 09:46 PM |
