removal of rocker panel after 10 years or so |
ndfrigi |
Sep 5 2013, 06:26 PM
Chris H. |
Sep 5 2013, 06:29 PM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Looks great. In the Midwest it would look like orange swiss cheese.
ndfrigi |
Sep 5 2013, 06:32 PM
cwpeden |
Sep 5 2013, 06:40 PM
Any particular reason for all the 16A fuses? (IMG:style_emoticons/default/poke.gif)
Sep 5 2013, 06:50 PM
Ya, well....we don't have earthquakes....
Dr Evil |
Sep 5 2013, 06:54 PM
Wow
billh1963 |
Sep 5 2013, 07:17 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
You're just showing off! (IMG:style_emoticons/default/laugh.gif)
ndfrigi |
Sep 5 2013, 07:19 PM
16 fuses? I don't know since I got it as is. Or is there a difference with the year and with center console with 3 gauges and with previous air conditioning. |
jimkelly |
Sep 5 2013, 07:21 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
first dibs on the longs (IMG:style_emoticons/default/biggrin.gif)
walterolin |
Sep 5 2013, 07:42 PM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
Obviously photoshopped. No rust, no jack stands.
Very nice. |
Jeffs9146 |
Sep 5 2013, 07:48 PM
Clean out those drain holes before you put it back together!
They fill with dirt and then the dirt holds moisture in and rust starts! Clean, flush, clean, blow air, let dry and spray rust inhibitor inside to seal it! |
ndfrigi |
Sep 5 2013, 11:14 PM
Clean out those drain holes before you put it back together! They fill with dirt and then the dirt holds moisture in and rust starts! Clean, flush, clean, blow air, let dry and spray rust inhibitor inside to seal it! Sir, which one is the drain hole? Is it the passenger side? No idea sir! Thank you for your concern! God bless! Noel |
Jeffs9146 |
Sep 5 2013, 11:25 PM
Clean out those drain holes before you put it back together! They fill with dirt and then the dirt holds moisture in and rust starts! Clean, flush, clean, blow air, let dry and spray rust inhibitor inside to seal it! Sir, which one is the drain hole? Is it the passenger side? No idea sir! Thank you for your concern! God bless! Noel One of the photos has an obvious hole but the other looks to be covered by the cobwebs or plugged up and painted over! Take a closer look and poke around to find it! |
ConeDodger |
Sep 5 2013, 11:37 PM
Apex killer! Group: Members Posts: 23,588 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Jeffs9146 |
Sep 5 2013, 11:53 PM
The hole is here on both sides!
cwpeden |
Sep 6 2013, 12:03 AM
in your second pic all the fuses under your dash except 2 are red. Red is a 16A. All but one should be a white 8A. I guess it only makes a diff if there is an electrical problem and it blows at over 16A instead of 8A. Maybe the electrical gurus could chime in.
ndfrigi |
Sep 6 2013, 12:19 AM
[/quote] Ok thank you sir and yes I will check on those holes. |
ndfrigi |
Sep 6 2013, 12:21 AM
in your second pic all the fuses under your dash except 2 are red. Red is a 16A. All but one should be a white 8A. I guess it only makes a diff if there is an electrical problem and it blows at over 16A instead of 8A. Maybe the electrical gurus could chime in. Maybe I should check those fuses and hoping someone can share a picture of their fuse box and details of those fuses. Thanks again! |
ndfrigi |
Sep 6 2013, 12:24 AM
ndfrigi |
Sep 6 2013, 12:34 AM
Thanks to Scott (Lucky25) who went to my house yesterday to drop some parts I bought from him with free delivery and he encouraged me to remove the rocker panel and check if there is no damage or rust hiding there.
Hoping that Scott will be able to find another 914 after loosing his car from a car theft. |
Lo-Fi Version | Time is now: 17th May 2024 - 07:45 PM |
