POS Plastic Ignition Switch, Any source for a good one |
Mblizzard |
Sep 10 2013, 08:16 PM
I have replaced 2 plastic switches for the ignition. It seems like these are so flimsy that the seem to flex an fail quickly. Getting tired of changing these. (IMG:style_emoticons/default/headbang.gif) Am I missing something here on the install? Seems straight forward there is only one screw. Or do I need to find a higher quality switch? If so where can I buy it?
timothy_nd28 |
Sep 10 2013, 08:20 PM
are you overloading the switch electrically?
Mblizzard |
Sep 10 2013, 08:42 PM
Kirmizi |
Sep 10 2013, 09:01 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
Try GPR (IMG:style_emoticons/default/biggrin.gif)
You're not the first to experience a crappy replacement switch. |
mrbubblehead |
Sep 10 2013, 10:10 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
the replacement turn signal switches suck too. im only getting nos electrical stuff from now on. the off shore parts are crap.
Mblizzard |
Sep 11 2013, 04:39 AM
Try GPR (IMG:style_emoticons/default/biggrin.gif) You're not the first to experience a crappy replacement switch. Looked on the web site but I was not sure that it was not the same one. I will call them. It seems that Beck-Arnley makes a decent one. |
ripper911 |
Sep 11 2013, 07:22 AM
corde pulsum tangite Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
If you're looking for 111905865L, we have some that are made by dansk. I assume they would be decent quality-wise.
Mblizzard |
Sep 11 2013, 08:01 AM
If you're looking for 111905865L, we have some that are made by dansk. I assume they would be decent quality-wise. Thanks. I looked on the site and did not notice it was Dansk. I think the problem with the after market switches is that the plastic used is too thin. This allows the plastic casing to flex because the spring tension when moving the switch to start us too high for the casing to resist. If you hold an after market switch up to the light and can clearly see the contacts you would suspect the casing is too thin. If there is also considerable resistance to overcome when moving to the start position then the switch will be prone to failure. Hold the switch by its self and operate it with a screw driver and observe the changes in the gaps where the switch snaps together. My stock switch, no change in the gaps at all. Aftermarket, very noticeable movement and separation of the parts. Interim solution was to JB weld both sides of the switch. Flex is gone and it seems to work. |
rhodyguy |
Sep 11 2013, 08:13 AM
missed this thread. check the fi one.
k |
rhodyguy |
Sep 11 2013, 08:34 AM
made in germany. (IMG:style_emoticons/default/shades.gif)
Attached thumbnail(s) |
ripper911 |
Sep 11 2013, 08:42 AM
It looks like the Dansk type has larger gaps to begin with.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i921.photobucket.com-11654-1378910525.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i921.photobucket.com-11654-1378910526.2.jpg) |
rhodyguy |
Sep 11 2013, 08:47 AM
pretty subtle difs in the dansk and the repop but they're there. interesting...
Mblizzard |
Sep 11 2013, 09:15 AM
It looks like the Dansk type has larger gaps to begin with. (IMG:http://www.914world.com/bbs2/uploads_offsite/i921.photobucket.com-11654-1378910525.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i921.photobucket.com-11654-1378910526.2.jpg) Just from my observation the key to evaluating the switch is if they change when subjected to the torque load imparted by the internal spring. If the gaps in the Dansk don't change like the cheap when torqued, then it is a better switch. Neither of the gaps as shown are big enough to cause the contact to not connect. How they change is the determining factor. It took me a long time to see this flaw. |
Mblizzard |
Sep 11 2013, 09:18 AM
That should solve it! |
rhodyguy |
Sep 11 2013, 09:19 AM
Mblizzard |
Sep 11 2013, 09:26 AM
At this point "Made In Germany" is where I am going! |
rhodyguy |
Sep 11 2013, 09:36 AM
okeydokey. pm sent. i'll go box stuff up and run to the usps when i receive a "go".
k |
StratPlayer |
Sep 11 2013, 10:17 AM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
StratPlayer |
Sep 11 2013, 10:20 AM
Porschef |
Sep 11 2013, 10:31 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
They're still available through Porsche, made in Germany and one has been trouble free in my car for over two years (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 17th May 2024 - 03:47 PM |
