I hope to be returning, 914 Less for about 2 years |
drive-ability |
Sep 11 2013, 09:52 PM
Senior Member Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 |
I left 914 ownership when my black V8 powered car burned in the Walmart parking lot some 2 years ago. I've been driving a Mercedes CL65 AMG as a replacement, but it's time to return.
I'm trying to make a deal on a project car being built in Orange County Ca. and hope to get the deal done soon. The MB is nice but nothing is quite like a 914. Surely the new project is going to have more than 4 cylinders but less than 12 like the MB. (IMG:style_emoticons/default/smile.gif) Crossing my fingers ! (IMG:style_emoticons/default/smile.gif) |
drive-ability |
Sep 29 2013, 05:02 PM
It's always best to use parts as designed by the factory. Meaning a non flip and factory shift linkage (IMG:style_emoticons/default/biggrin.gif) I think my G-50 is worth about 1,500. Where can I get an adaptor for the LS1 to the Cayman S ? I haven't bought the clutch packages yet so now is the time to change course. Wonder, is the flywheel set up for the G-50 will work ? To me its critical for the shifting to be perfect. My old 930 box was a bit cumbersome and slow unless you just slam things around, it took all I could give it however (IMG:style_emoticons/default/biggrin.gif) My bet is the freeway rpm @ 70 mph would also be much better. Meaning lower RPM compared to the G-50. Again a very important feature ! I'll call Renegade maybe they can shine some light on the subject. |
Mike Bellis |
Sep 29 2013, 05:59 PM
It's always best to use parts as designed by the factory. Meaning a non flip and factory shift linkage (IMG:style_emoticons/default/biggrin.gif) I think my G-50 is worth about 1,500. Where can I get an adaptor for the LS1 to the Cayman S ? I haven't bought the clutch packages yet so now is the time to change course. Wonder, is the flywheel set up for the G-50 will work ? To me its critical for the shifting to be perfect. My old 930 box was a bit cumbersome and slow unless you just slam things around, it took all I could give it however (IMG:style_emoticons/default/biggrin.gif) My bet is the freeway rpm @ 70 mph would also be much better. Meaning lower RPM compared to the G-50. Again a very important feature ! I'll call Renegade maybe they can shine some light on the subject. Kennedy Engineered Products will have the adapter, flywheel, clutch, etc... My tranny shifts perfect. Like a Cayman S... |
drive-ability |
Sep 29 2013, 11:08 PM
It's always best to use parts as designed by the factory. Meaning a non flip and factory shift linkage (IMG:style_emoticons/default/biggrin.gif) I think my G-50 is worth about 1,500. Where can I get an adaptor for the LS1 to the Cayman S ? I haven't bought the clutch packages yet so now is the time to change course. Wonder, is the flywheel set up for the G-50 will work ? To me its critical for the shifting to be perfect. My old 930 box was a bit cumbersome and slow unless you just slam things around, it took all I could give it however (IMG:style_emoticons/default/biggrin.gif) My bet is the freeway rpm @ 70 mph would also be much better. Meaning lower RPM compared to the G-50. Again a very important feature ! I'll call Renegade maybe they can shine some light on the subject. Kennedy Engineered Products will have the adapter, flywheel, clutch, etc... My tranny shifts perfect. Like a Cayman S... What engine are you running now ? Can you post or send me some pictures of your car and the transmission ? Thanks for the information !!!! |
Mike Bellis |
Sep 30 2013, 07:17 PM
What engine are you running now ? Can you post or send me some pictures of your car and the transmission ? Thanks for the information !!!! I cheated, sort of. I'm running an Audi 1.8T that happens to have the same bolt pattern as the Cayman S transmission. A direct bolt on conversion. Here is a pic of the engine and the old 5 speed. The 6 speed looks similar... Here is the 5 speed on the Left and 6 speed on Right Here is the 6 speed side view. This is a very similar tranny to the Audi 01E that Andys is running with his LS1 914. The 01E is more pricey and harder to find since it is a Euro FWD only tranny. he Cayman S & Boxster S is a Getrag 466 which is also available with some Audi A8 vehicles. The Porsche version of the 466 comes with 108mm flanges. Not sure what the Audi version comes with. I bolted 930 CV's right to the flanges with 6 bolts in lieu of the stock 930 4 bolts and 2 pins. Another alternative is importing an Audi TDI 5 speed from Europe. You will only have 5 gears but the ratios are almost perfect for a V8 AND the trannys go for around $400 with another $300 for shipping. Very stout trannys. The TDI 5 speed is hard to find in the US but UK ebay has a ton of them. That is where I got my 466. Mine was $700+$300 to ship. |
Lo-Fi Version | Time is now: 13th May 2024 - 11:18 PM |
