Hoosiers are cool., Drove on 'em today. |
Trekkor |
Dec 13 2004, 09:20 PM
Roads were dry...Why not?
These things really, really, schtick. I like them very much (IMG:style_emoticons/default/wub.gif) They love to turn in and they thanked me for all that negative camber I gave them. They got a warm feeling throughout. KT |
drew365 |
Dec 13 2004, 09:23 PM
Why are you driving Hoosiers on the street? If you have money to throw away PM me. (IMG:style_emoticons/default/biggrin.gif)
The stick will wear out way before the tread does. |
Trekkor |
Dec 13 2004, 09:31 PM
Simulated session... (IMG:style_emoticons/default/wink.gif)
They come off tommorrow and go into hibernation. I just had to...Know. KT |
drgchapman |
Dec 13 2004, 11:13 PM
Current Stable Group: NoClassifiedAccess Posts: 922 Joined: 20-September 04 From: Portland, OR Member No.: 2,789 Region Association: Pacific Northwest |
Got my first set about 3 months ago. Autocrossed them twice, Ran pretty good too. Very impressive. They do love the negative camber, I could only get neg 1-1/2 at each corner. I have yet to find the limit on them. Next year........
Trekkor |
Dec 14 2004, 06:39 PM
What PSI are people running in these tires.
I ran 32 in the rear and 30 up front. Felt good. Shoud I run them lower? Randal, didn't you say 25 psi? KT |
Randal |
Dec 14 2004, 08:22 PM
Autocrossing I ran them at 23 in front, 25 in back.
Road racing I ran them 33/34 (front/back) and they heated up to 136 after 15 minutes at Thunderhill. This was before Brad rebuilt my suspension, so I'd assume on a car properly set up (like yours) they'd get hotter. BTW it was fun going into 8 at Thunderhill flat out (counterclockwise) and watching the 911's behind me brake. Pulled them about 8 car lengths there. The only problem was if you started the straight with a 911 right behind you.... they’d pull you 8 car lengths before you hit turn 1 and started to reel them back in again. But as Hank Watt's says, if the car behind you catches you, he's faster. Sometimes we have to feel good just doing that, but the 911 guys simply hated (HATED) to pull over for a 914. (IMG:style_emoticons/default/biggrin.gif) |
drgchapman |
Dec 14 2004, 09:13 PM
Got my best times with 28 front, 30 rear. I was dropping pressure as runs passed. Ran out of runs before going lower. Increases of 1/2 second each run as pressure was reduced. But, was using up the tread, so I think I was reaching the sweet spot. Check your roll over, deflate until all tread used sidewall-sidewall. Finished 1 sec behind JP's 914-6 with my little 2.0.
Trekkor |
Dec 15 2004, 12:51 AM
Lo-Fi Version | Time is now: 12th May 2024 - 10:26 AM |
