broke a fan blade, what to do |
bernbomb914 |
Dec 14 2004, 08:05 PM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
pulled engine and found broken fan blade. can I remove three more to make it uniform? I remember somewhere the if you remove some blades it works better. what should I do?
Bernie (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/wacko.gif) (IMG:style_emoticons/default/blink.gif) |
tracks914 |
Dec 14 2004, 08:18 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
Search ebay and buy a new one. they run about $10.
Yes you can even out but the engineers at the factory put them all in there for a reason. |
Joe Ricard |
Dec 14 2004, 08:19 PM
Not for street engines. You mat get away with one on the opposing side. I did that and it was fine.
Is this an early or late fan? |
bernbomb914 |
Dec 14 2004, 08:29 PM
see pic I dont know what year it is
Joe Ricard |
Dec 14 2004, 08:34 PM
Early
bernbomb914 |
Dec 14 2004, 08:36 PM
whats better?
Bernie |
Joe Ricard |
Dec 14 2004, 08:42 PM
Just a different design. blades are same size I like the early with the ruber nose cone. Seems more aerodynamic to me. However no scientific proof.
BTW you have mail. |
Eric_Shea |
Dec 14 2004, 08:52 PM
Pretty much covered Here
dmenche914 |
Dec 14 2004, 11:33 PM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
if you can get one, add one of them nifty fan covers found on Type IV Bus engines. If is a plastic mesh screen, and bolts to the fan house (the 914 fan house should already have the boss for the bolts, maybe already drilled and tapped for you)
This will help stop leaves from getting sucked in, that will get stuck on the cooling fins, and increase the temps. The plastic mesh covers is great. dave |
Lo-Fi Version | Time is now: 13th May 2024 - 01:23 PM |
