2.0 Sheet metal, 2.0 Sheet metal |
Teknon |
Dec 15 2004, 09:15 AM
The more I learn the dumber i think I am Group: Members Posts: 357 Joined: 10-August 04 From: Denver, Colorado Member No.: 2,505 Region Association: Rocky Mountains |
Is there a difference between the sheet metal (shroud etc.) on a 2.0 vs. a 1.7 or 1.8. (IMG:style_emoticons/default/sad.gif)
Joe Bob |
Dec 15 2004, 09:20 AM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Yup....the spark plug holes are differrent...
ruddyboys |
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
the 1.7 and the 1.8 should be the same. the 2.0 has the spark plug holes in a different location.
ClayPerrine |
Dec 15 2004, 09:22 AM
Life's been good to me so far..... Group: Admin Posts: 15,463 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Simple answer... Yes. The 2.0 engine has different cylinder heads. Those heads have different spark plug angles, so the engine tin had to be remade for the 2.0. You can use the 1.7/1.8 tin if you weld up and redrill the holes for the spark plugs in the correct location for the 2.0 heads. The rest of the tin is identical.
IIRC... the 1.7/1.8 tin has a corner where the 2.0 spark plug wires have to go, so they made the 2.0 tin more rounded on top. Keep asking questions... it's the only way to learn. |
brant |
Dec 15 2004, 09:23 AM
914 Wizard Group: Members Posts: 11,623 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Teknon,
sorry for the hi-jack.. I see your local as denver. we have a small denver 914 group I'd like to tell you about... |
Teknon |
Thank you my 914 bros., Joe
Dave_Darling |
Dec 15 2004, 06:01 PM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
In addition, the tail-shifters used a different piece of bottom engine tin (bolts to the crankcase on one side and the heat exchangers on the other) on the left side of the engine. The old piece interfered with the side-shifter's rear shift rod, so they changed it.
Also, both the left and right bottom tin pieces were changed in 75-76 because of the new heat exchangers. The 72-only rear panel has a large fitting in it for an intake pre-heat hose; I don't know if those were ever actually hooked up but they are there. --DD |
BMartin914 |
Dec 15 2004, 08:20 PM
||| Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
All the responses are dead-on Joe.
Brant, Joe's a great new guy! He found all of us through the C914 board. When you get some time away from your bad a$# race car we'll all get together. By that time TLB might be running. What do you say Joe? |
Teknon |
Dec 16 2004, 12:57 AM
Hey Ben and Brant,
I like to call the club "C14" since most Porsche’s are practically 9 something anyway. Working on these old things is like Carbon Dating. They use Carbon 14/ C14 for that. It would make a nice hat "a C w/ an exponent of 14". Whatever! TLB just got her Greeny front Bilstein's on. Now to attempt the sways! Probably should have done it the other way around. Defrost window about to go in. Hope so, the entire interior is all over the place. I have to win the lottery so I can afford this white elephant. Still need to drop the engine and fkw/ that. That disc Peter made is great. Blows every thing up and has the corresponding Legends. Looks like some people are going to Kev’s on Sunday. Hope I can make it. Looking forward to meeting you Brant and always great to see you Ben. Joe (IMG:style_emoticons/default/wavey.gif) |
brant |
Dec 16 2004, 10:02 AM
Joe,
about half way through this thread I figured out it was you. hope to meet you sunday! brant |
Lo-Fi Version | Time is now: 15th May 2024 - 08:23 PM |
