Bung for EGO Sensor, 1.7 SS Heat Exchangers |
wndsnd |
Sep 20 2013, 08:17 AM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
It says to mount the bung for the sensor at least 18" from the exhaust port.
That would put it in the middle of the exchanger Can I mount this in the pipe after the exchanger and before the muffler or is that too far away from the head. How have you done this? Thanks John |
kevin311 |
Sep 20 2013, 08:30 AM
Member Group: Members Posts: 105 Joined: 22-May 10 From: Tampa Bay Area Member No.: 11,752 Region Association: None |
I had a bursch muffler and mounted my sensor in the collector after the heat exchangers. It worked great for me. Just make sure it is mounted between 9-3 on the pipe to prevent moisture buildup on the sensor.
My sensor is also self heating so that may be a factor in how close you need to mount it to the port. Hope this helps. |
wndsnd |
Sep 22 2013, 07:00 PM
I am using a stock muffler. It will be easier mounting there tnan on the harder stainless pipe.
Lo-Fi Version | Time is now: 18th May 2024 - 01:15 PM |
