wndsnd
Sep 20 2013, 08:17 AM
It says to mount the bung for the sensor at least 18" from the exhaust port.
That would put it in the middle of the exchanger
Can I mount this in the pipe after the exchanger and before the muffler or is that too far away from the head.
How have you done this?
Thanks
John
kevin311
Sep 20 2013, 08:30 AM
I had a bursch muffler and mounted my sensor in the collector after the heat exchangers. It worked great for me. Just make sure it is mounted between 9-3 on the pipe to prevent moisture buildup on the sensor.
My sensor is also self heating so that may be a factor in how close you need to mount it to the port.
Hope this helps.
wndsnd
Sep 22 2013, 07:00 PM
I am using a stock muffler. It will be easier mounting there tnan on the harder stainless pipe.
