FS: ignition parts aftermarket |
maddog |
Sep 23 2013, 06:39 AM
Member Group: Members Posts: 200 Joined: 19-May 03 From: Grand Rapids Michigan Member No.: 710 Region Association: None |
914itis |
Sep 23 2013, 07:33 AM
Pm sent for fan shroud.
JmuRiz |
Sep 23 2013, 11:03 AM
914 Guru Group: Members Posts: 5,434 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Checking with my brother, will PM you his wants when he talks with his engine guy.
0396 |
Sep 23 2013, 11:33 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
these are all best offer and shipping paid by buyer, I prefer paypal as a payment. Please don't flame on a price if I am way off, I have an idea of what some things are worth but have been out of touch with 911 parts for a long time, I spend all my time in the 914 forums, email or text me for pictures or details, could work out a package deal because this is almost everything for a complete 2.4e build with high compression pistons minus carbs/mfi? email Dave @ maddog0726@comcast.net or call/txt 616-481-eight444 2.2 S pistons with new rings $1000 1973 911/51 2.4T short block $850 1972 911/51 2.4T long block has a spun bearing $1250 2.4 E cams $450 2.4 E Bosch distributer w/new cap rotor and points $450 Oil cooler $300 Auxiliary oil cooler w/adaptor and stainless steel lines $150 Crane HI-6 w/rev limiter $180 Crane Fireball PS92 coil $50 Allison XR700 optical points $65 Accel Super Stock coil new in box $25 Venturie set 46mm $75 K&N filters and housings New $250 Super traps stainless steel $200 Fan 11 blade/alt/housing/strap /air vain $400 Fan shroud painted red $50 Fan black w/alt harness $100 Pressure fed tensioner covers/oil lines/gaskets $325 Oil return tube seals, intake gaskets for carbs, carb base gaskets, chain housing gaskets, rear crank seal 999-113-057-52, valve cover gasket set, valve guides/seals for 2.4 heads, 2.4 cyl base gaskets 2.2s pistons....what are the specs and or mfg? |
maddog |
Sep 23 2013, 12:28 PM
911 2.2 S pistons Mahle 84mm bore ring sizes are 1.5,1.5, 4mm
[/quote] 2.2s pistons....what are the specs and or mfg? [/quote] |
maddog |
Oct 1 2013, 01:11 PM
bump
maddog |
Aug 6 2014, 07:48 AM
Still have these available
Lo-Fi Version | Time is now: 9th June 2024 - 02:22 PM |
