QUOTE(maddog @ Sep 23 2013, 05:39 AM)
these are all best offer and shipping paid by buyer, I prefer paypal as a payment. Please don't flame on a price if I am way off, I have an idea of what some things are worth but have been out of touch with 911 parts for a long time, I spend all my time in the 914 forums, email or text me for pictures or details, could work out a package deal because this is almost everything for a complete 2.4e build with high compression pistons minus carbs/mfi? email Dave @ maddog0726@comcast.net or call/txt 616-481-eight444
2.2 S pistons with new rings $1000
1973 911/51 2.4T short block $850
1972 911/51 2.4T long block has a spun bearing $1250
2.4 E cams $450
2.4 E Bosch distributer w/new cap rotor and points $450
Oil cooler $300
Auxiliary oil cooler w/adaptor and stainless steel lines $150
Crane HI-6 w/rev limiter $180
Crane Fireball PS92 coil $50
Allison XR700 optical points $65
Accel Super Stock coil new in box $25
Venturie set 46mm $75
K&N filters and housings New $250
Super traps stainless steel $200
Fan 11 blade/alt/housing/strap /air vain $400
Fan shroud painted red $50
Fan black w/alt harness $100
Pressure fed tensioner covers/oil lines/gaskets $325
Oil return tube seals, intake gaskets for carbs, carb base gaskets, chain housing gaskets, rear crank seal 999-113-057-52, valve cover gasket set, valve guides/seals for 2.4 heads, 2.4 cyl base gaskets
2.2s pistons....what are the specs and or mfg?
