Interesting Items, Any Ideas? |
Mblizzard |
Sep 23 2013, 11:08 AM
There have been a few items that I have encountered recently that just seemed very expensive for what they were. Getting closer to potentially getting them to a much cheaper price.
Sep 23 2013, 03:08 PM
Front suspension bushing?
--DD |
Mblizzard |
Sep 23 2013, 03:23 PM
3-D printed Venturi's.
Thoughts? |
codices |
Sep 23 2013, 03:58 PM
Member Group: Members Posts: 95 Joined: 9-October 08 From: Morrison, Colorado Member No.: 9,626 Region Association: Rocky Mountains |
These are tools for removal and replacement of small hub caps on factory teener wheels without bending or denting.
rhodyguy |
Sep 23 2013, 04:05 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
what are they made of? can the material handle a flash back thru the carbs?
Mblizzard |
Sep 23 2013, 06:36 PM
Kevin they should be fine as the are high temp PLA with a melting point over 110 C.
Sep 23 2013, 06:41 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Cool.
What materials can you print? I would be interested in some custom velocity stack. |
Mblizzard |
Sep 23 2013, 06:48 PM
For the velocity stacks I would go with ABS lower melting temp but a little stronger material.
Right now we are mainly doing PLA and ABS. But we can do most extrudeable plastic. Let me know what you would like and we can either generate the or use your design. |
Sep 23 2013, 06:49 PM
Is it just plastic?
Mblizzard |
Sep 23 2013, 06:59 PM
Yep but it has an additional solvent resistant coating on it for fuels and and air flow. If there is a failure of the plastic due to heat, the impacts on the engine are quite small.
bulitt |
Sep 23 2013, 07:12 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
If I could offer a request, and don't know what volume you are talking about, but the front side marker assembly that holds the bulbs (not the lens) is NLA, Kinda thought about having a run of 1000 made up but possibly something you could offer.
Eric_Shea |
Sep 23 2013, 07:15 PM
Sep 23 2013, 07:29 PM
Questin is really, can you only print plastic?
Mblizzard |
Sep 23 2013, 07:31 PM
If I could offer a request, and don't know what volume you are talking about, but the front side marker assembly that holds the bulbs (not the lens) is NLA, Kinda thought about having a run of 1000 made up but possibly something you could offer. Being new to this I don't know all of the in's and outs but there are a number of places where you can essentially print whatever volume you want. But the printing capacity is not the valuable part. The STL file used to print the file holds the value. When you use one of the print on demand services you send that valuable file to them and it usually ends up in China before your part is done. That's just my impression and I could be wrong. If you have the file, the age and demand of this part makes it an unlikely target for others. The only problem would be incorporating the electrical connections. But certainly it can be done. While we don't have the file or capacity at this point we would be happy to work with you on this. |
Mblizzard |
Sep 23 2013, 07:52 PM
Lo-Fi Version | Time is now: 25th May 2024 - 01:58 PM |
