Out with the old and in with the Roo, Out with the 4 and in with the 6! |
A&P Mech |
Sep 24 2013, 06:49 AM
Member Group: Members Posts: 401 Joined: 10-September 13 From: United States Member No.: 16,371 Region Association: Rocky Mountains |
Hello 914 World! I am a new member of the site and a new owner of a 1974 2.0l project car. I picked this car up from a great guy north of Denver that was reducing his 914 collection down to two cars.
As you can see from the pictures the car arrived in pieces. Everything appears to be in pretty good shape. The Hell Hole is solid and is almost rust free! I am fortunate to have another 914world member "rnellums" helping to sort and rebuild the car. I have attached a few pictures that I took yesterday when we rolled the car into it's new home. Ray |
A&P Mech |
Apr 26 2015, 07:04 PM
Update: The progress continues on my EJ253. So far I have replaced the head gaskets, timing belt, water pump and thermostat. The top end is back together and the intake manifold has been flipped and installed. The drive by wire throttle body has been replaced with a cable actuated version. The oil pan was removed and replaced with a mid engine pan from Outfront Motorsport. I have removed the EGR system and machined a block off plate for the EGR valve. The EGR tube was removed and the ports are plugged. The alternator was relocated with an Outfront Motorsports bracket. I still need to design and machine a bracket to relocate the coil pack. As soon as that is completed I can pull the flex plate and install the flywheel/clutch and mate the transmission up to the engine.
I am starting to think about the cooling system. The inlet and outlet on my Subaru motor is 1.5" I am having a hard time finding 1.5" heater hose in bulk. I have found 1.25" for about $6.50/foot. What is everyone running under the car? I was thinking I could run the 1.25" and make a few adapters to step the hose up for the engine connections. Any suggestion would be greatly appreciated. I know Renegade does make a good system but I am not willing to give them a grand for it. (IMG:style_emoticons/default/blink.gif) Things are moving along. |
Lo-Fi Version | Time is now: 26th May 2024 - 12:57 PM |
