Out with the old and in with the Roo, Out with the 4 and in with the 6! |
JRust |
Aug 31 2015, 02:58 PM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I had to have a cutout for my starter too. Doesn't come into the trunk a lot but wouldn't fit under (IMG:style_emoticons/default/sad.gif) . Ditto on the clutch arm. I have a return line on my setup (IMG:style_emoticons/default/confused24.gif) . Can't remember if there is a pressure regulator. Don't remember there being one there by my pump (IMG:style_emoticons/default/idea.gif) . Damn another thing I can't go out & look for you. I am finally getting to know my setup better (IMG:style_emoticons/default/rolleyes.gif) . One drawback to not doing the conversion myself originally.
Mueller |
Aug 31 2015, 04:34 PM
Great progress!
You must be LOVING that lift! Solid rivets eh? I wonder what I ever did with my 1st bucking bar I made in school? |
Chris H. |
Aug 31 2015, 06:21 PM
Senior Member Group: Members Posts: 4,028 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Yeah I agree, your axles should be fine like that. Take a look at 914 axles. They're a lot more angled upward than those are sideways.
Have you found the service manual for that engine? What year and car would it have come out of? Seems impossible not to have a return line. |
914forme |
Aug 31 2015, 06:50 PM
Not impossible, lots of EFI systems don't have return lines, just a little odd to us since we have lived with them for so long. My son's old Civic did not have one, fuel pressured reg is before the inlet, so it backs up pressure onto the pump. Wears out the pump faster? But Honda saved $10000000s on the lack of return line over the production run of the car.
A&P Mech |
Aug 31 2015, 08:03 PM
Member Group: Members Posts: 400 Joined: 10-September 13 From: United States Member No.: 16,371 Region Association: Rocky Mountains |
The lift is awesome!!!! It is easily the best purchase I have made in a long time. I was able to remove my engine/transmission twice today with out a single jack stand and without any help.
Chris, the engine is a 2007 2.5 SOHC. I have found adjustable regulators that have a bypass. http://www.summitracing.com/parts/aei-13129/overview/. I would like to know how Subaru is achieving the same thing. |
Chris H. |
Aug 31 2015, 08:26 PM
Sent you a PM. Your eyes will be tired soon. Give the engine section a read and see what the FI setup looks like. My brain can't absorb any more Subaru diagrams.
A&P Mech |
Sep 1 2015, 12:38 PM
It turns out that Subaru moved the fuel pressure regulator to the fuel tank in 2006. I gave Outfront Motorsports a call to purchase a regulator with a bypass. All I can say is they are an awesome group of guys!!!! Instead of selling me a new part that I didn't need they provided a solution. I am going to tap into the far side of the rail/line and simply install a regulator.
A&P Mech |
Sep 19 2015, 07:16 AM
It's runs! I started my Subaru conversion last night for the first time. I am not sure my neighbors were as excited about it as me. It ran with an open header. (IMG:style_emoticons/default/evilgrin.gif) It was loud.
https://youtu.be/rmFd0-R9cNc I still have to complete the axles, mount the ECU and install the shift cables. I am getting close! |
rnellums |
Sep 19 2015, 07:31 AM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
Hell yeah Ray! Now let's get some snows for winter driving!
A&P Mech |
Sep 19 2015, 08:06 AM
Yeah, I got it running just it time for winter. (IMG:style_emoticons/default/dry.gif)
76-914 |
Sep 19 2015, 09:23 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Congratulations! (IMG:style_emoticons/default/piratenanner.gif) Let's see some close ups of your riveting. AN 426's?
A&P Mech |
Sep 19 2015, 04:07 PM
Congratulations! (IMG:style_emoticons/default/piratenanner.gif) Let's see some close ups of your riveting. AN 426's? You are correct. AN 426's. Your build thread has been an inspiration. I have read it several times! I am getting ready to start my hydraulic clutch build. I am using the info that you and Chris posted in your thread. Do you have any tips that might help it go smoothly? Ray |
76-914 |
Sep 19 2015, 05:28 PM
Ignore my bolt hole dimensions. If you can grab an old brake MC, use it as a drill guide for your bolt holes and of course you will have the clutch MC to use as a guide for the other 2 bolt holes. When the plate is drilled out, place it in a vice and center the holes horizontally. Then mount the clutch MC and twist the plate 3 degrees down. I use a large pipe wrench and grab the plate around the mounted MC. Having the MC bolted down keeps the plate from twisting the flat surface the MC mounts to. Use the center of the large hole on the clutch master as a guide to locate center of the hole you will drill in the floorboard. Your going to love that conversion your building and you won't be afraid to drive cross country in it, either. (IMG:style_emoticons/default/beerchug.gif)
A&P Mech |
Sep 19 2015, 05:34 PM
Ignore my bolt hole dimensions. If you can grab an old brake MC, use it as a drill guide for your bolt holes and of course you will have the clutch MC to use as a guide for the other 2 bolt holes. When the plate is drilled out, place it in a vice and center the holes horizontally. Then mount the clutch MC and twist the plate 3 degrees down. I use a large pipe wrench and grab the plate around the mounted MC. Having the MC bolted down keeps the plate from twisting the flat surface the MC mounts to. Use the center of the large hole on the clutch master as a guide to locate center of the hole you will drill in the floorboard. Your going to love that conversion your building and you won't be afraid to drive cross country in it, either. (IMG:style_emoticons/default/beerchug.gif) Thank you very much for the help! I am really looking forward to driving it. I hope to drive to the RRC next year. Ray |
Chris H. |
Sep 19 2015, 06:55 PM
It's pretty rewarding when it fires up isn't it? Nice. Just got back from a lap in mine. Clutch still works great. That plate Kent made is the key.
JRust |
Sep 19 2015, 07:09 PM
Congrats bud! Only which you & Ross could have made it out for Red Rocks. Been a fun weekend & almost over. I head back tomorrow but my car worked great. Next time but can't wait to see some video of you driving yours. Way to go (IMG:style_emoticons/default/piratenanner.gif)
A&P Mech |
Sep 19 2015, 09:31 PM
Chris, I have been working on the car non-stop for the last couple of months. It was very nice to hear the engine fire up for the first time. It helps keep the momentum up. I would like to drive the car before the snow starts to fall.
It is good to hear that the clutch mod is still working out well. It looked like a solid install and smart design. I really appreciate that you and Kent took the time to figure it out and share it with everyone here. You guys Rock! (IMG:style_emoticons/default/pray.gif) Jamie, The EMS Stinger and Outfront wiring harness sure made the electrical install easy. Thanks for helping me decide to go that way when you were here in Denver. |
A&P Mech |
Sep 20 2015, 12:06 PM
I just wrapped up the cable shift install. Next on the list is the hydraulic clutch.
Sep 20 2015, 12:11 PM
914-6 GT in waiting Group: Members Posts: 19,244 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
A&P Mech |
Sep 20 2015, 12:14 PM
It is. Ian did a great job on the kit.
Lo-Fi Version | Time is now: 29th April 2024 - 01:21 AM |
