six conversion parts needed, list of parts for 3.0 |
pete-stevers |
Dec 16 2004, 12:57 AM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
looking for for an extesive list of parts to buy for my 3.0 six conversion. I have a complete 911sc for parts for the engine, tac...
what I am looking for is oil cooler coil oil tank hoses engine mount(type) recomendations on the tranny rebuild and gears and cooler etc.... I have converted the front suspension and rear brakes to vented/ but have lost the ebrake(any Velious rear kits available) (IMG:style_emoticons/default/confused24.gif) the car is to be a road car with the remote possibility of auto-x Any recomendations for dealers on these parts, or private?? (IMG:style_emoticons/default/wink.gif) ? Steve |
914Timo |
Dec 16 2004, 01:10 AM
******* Group: Members Posts: 743 Joined: 13-January 03 From: Finland Member No.: 137 Region Association: Europe |
Use 915 trasmission and WEVO sidesifter mechanism. The gear rations of stock 901 are not very good with 3.0L six. It is not cheap alternative, but worth the $$.
Use RJ type engine mount. I did mine myself and saved lots of $$$. Oilcooler.... If you mean remote oilcooler, first make sure you will need one. If your climate is not hot, you dont need one. Good luck (IMG:style_emoticons/default/aktion035.gif) |
IronHillRestorations |
Dec 16 2004, 08:26 AM
I. I. R. C. Group: Members Posts: 6,717 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
QUOTE(914Timo @ Dec 15 2004, 11:10 PM) Use 915 trasmission and WEVO sidesifter mechanism. The gear rations of stock 901 are not very good with 3.0L six. It is not cheap alternative, but worth the $$. Use RJ type engine mount. I did mine myself and saved lots of $$$. Oilcooler.... If you mean remote oilcooler, first make sure you will need one. If your climate is not hot, you dont need one. Good luck (IMG:style_emoticons/default/aktion035.gif) I liked the stock 4 cyl gearing for my 3.0. The only thing I would've changed is maybe a little taller 5th for highway cruising. There's more than one way to add a external oil cooler. I put one in the right side rear 1/4 panel, in the wheel house, directly behind the battery tray. Worked fine, but I didn't do track events. Probably would be OK for autocross. Steve, PM me. I've got lots of conversion parts in stock, including Rich's mounts, oil tanks, sheetmetal, etc. |
Root_Werks |
Dec 16 2004, 09:11 AM
Village Idiot Group: Members Posts: 8,319 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
You will also need the little stuff, but depends on which trany route you take:
Muffler hanger 2.0 works 914-6 tin Bell crank for throttle linkage If you keep your 901, straightened shift bar. I make all the above stuff (sameless plug) (IMG:style_emoticons/default/biggrin.gif) If you use the 915, I don't know if my bell crank works on that. On the plus side, you can keep your 3.0 flywheel, otherwise if you keep the 901, you have to buy one specific for the 3.0/901 combo. There has been a recent topic on the cross bars. I think I would go with a bulk head mount system if I were you. For a 3.0 the cross bar may not work for the long term from the pic's I have been seeing? (IMG:style_emoticons/default/sad.gif) |
Dave_Darling |
Dec 16 2004, 12:46 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Have you seen the articles on the Bird site?
http://www.pelicanparts.com/914/914-6_cons..._info_guide.htm http://www.pelicanparts.com/914/914-6_cons..._price_list.htm (Note--the second link does not show a complete set of parts you need... Plus, there is more than one way to convert a car.) --DD |
Lo-Fi Version | Time is now: 13th May 2024 - 05:14 PM |
