Signal Single Orange 74 EG33 Swap, Gone but not forgotten |
914forme |
Sep 25 2013, 07:47 PM
Okay this is the car in all its glory ugly as heck, but hey its an auto-x car. (IMG:style_emoticons/default/new_shocked.gif) This one is from my first season of auto-x with this car.
Heres what it looks like today. Made it even uglier (IMG:style_emoticons/default/barf.gif) Here is the goal, I can sketch ideas, but I can not draw at the level of others on this forum. Thank you 914 Visulizer. and my black pen. Now if I could find a good front view. And the flares are not on the car since I'm not using GT Flares. But you get the general idea. |
rick 918-S |
Sep 26 2013, 09:38 PM
Hey nice rack! -Celette Group: Members Posts: 20,441 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Can you re-drill the centerlines? I did that to a set of Torque Thrust's back in the day. I had a machine shop countersink in off set washers. I drag raced on them with 500 hp.
914forme |
Sep 27 2013, 06:59 AM
Can you re-drill the centerlines? I did that to a set of Torque Thrust's back in the day. I had a machine shop countersink in off set washers. I drag raced on them with 500 hp. Thats a great idea Rick. Quick search found these CMS Wheels Custom backspace wheels.Since the centers are solid, should be able to have them indexed and drilled for 5x130. Like people do for rear hubs. I'm sure I would have to sign a liability waver. USA made custom back spacing, bolted or welded wheel halves your choice. for a 8" wide rim it came out to $231. Or you can get Centerline drags from Summit for $237 in an 8.5" width, can't change the back spacing on these. Something to be said about a forged wheel though. Why is it so hard to find wheel weights (IMG:style_emoticons/default/ar15.gif) Now to find a used set, as I have less in my tranny than these wheels would cost me. Also I have to check my transcode, to get my ratios and final drive. If you want to say its a stock WRX US spec transaxle, you can use this site to see what different wheel and tire combinations will do for speed at a given RPM. What would be cool is to also have a system to project how long it would take you to get to a certain speed with rotational mass. I know a ton of variables to equate. |
Lo-Fi Version | Time is now: 4th May 2024 - 03:34 AM |
