Signal Single Orange 74 EG33 Swap, Gone but not forgotten |
914forme |
Sep 25 2013, 07:47 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Okay this is the car in all its glory ugly as heck, but hey its an auto-x car. (IMG:style_emoticons/default/new_shocked.gif) This one is from my first season of auto-x with this car.
Heres what it looks like today. Made it even uglier (IMG:style_emoticons/default/barf.gif) Here is the goal, I can sketch ideas, but I can not draw at the level of others on this forum. Thank you 914 Visulizer. and my black pen. Now if I could find a good front view. And the flares are not on the car since I'm not using GT Flares. But you get the general idea. |
914forme |
Sep 29 2013, 08:22 PM
Only got a work a little Saterday, and maybe an hour today, my heart just wasn't in it, after the rainy Cincinnati Show. (IMG:style_emoticons/default/sad.gif)
I did get items pulled from my trans, and re-installed. Tools needed. 12mm socket 14mm socket 27mm socket Socket Wrench, or impact wrench for disassembly Torque wrench for assembly Punch Big Hammer Big Dead Blow Hammer with a Soft Face Couple items to pry with Cold Chisel Small pick Something to clean gasket material off with. Two items to lock the drive shafts or flanges in place. I used to pipe wrenches. Tube of Yamahabond or Hondabond Oil dry see next item. (IMG:style_emoticons/default/sad.gif) First make sure all the Tranny fluid is drained out of the trans. Or else you get a slick the size of the Exon Valdez spill. Pull the bits and pieces not needed for the shifter. Its a roll pin, drive it out with a punch and a BFH. (IMG:style_emoticons/default/smash.gif) Watch pin fly across garage, you my want to save these pieces I'm going to modify (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/smash.gif) them for the basis of my cable shifter. It should look like this. Remove all the bolts holding the nose onto the tranny. Put these aside for cleanup and re-use if your cover will allow, or measure them up for some new shinny ones. Next pick up your Dead Blow or suitable alternative, and give it a few good whacks to loosen the adhesive, and hopefully open it up enough to get a nice wide pry in there with out damaging the mating surface. Once done heres the guts you get to pull out. Next you pull these out. Grab ahold of both and lift they come out together. And you are left with this. Pieces removed Next up you have to get this nut off the shaft. It is a 27mm and is peened over. Mine was done in 4 spots. Some assembly line worker in Japan, did his job with vigor. (IMG:style_emoticons/default/smilie_pokal.gif) Out comes the punch and BFH, and undo all his hard work. Next I took my impact wrench and locked the axles and zipped it off. This is the first set of items you will pull, nut and 2 washers. Next slip the shaft sleeve off the shaft. for lack of better terminology. There will also be a stack of washers, hardened bearing surfaces, and a roller bearing. A pick is helpful here to get these all off the shaft. The last one gave me fits but it has to come out or else the spool will not fit correctly This picture shows its not fully seated. Next you will have to fiddle a little turning the shafts to get them lined up to get the spool to lock both inner and outer shafts together. And then with some luck it will drop into position. Next add the washer that was next to the nut on your gear stack. Thread it on, then torque it down, to ??? I forgot its in the FSM for the WRX sorry. Don't forget to lock the shafts again. Easy enough. Peen over the nut to lock it into place. You can use a punch, I found a cold chisel did the job with one whack per indent. Yes I followed the original assemblers lead and and did it four times. Next up get rid of the factory sealant left on the mating surface. I stuffed the inside with paper towels, and started to clean it up with a angled die grinder and a scotch brite pad. done. Clean up with what ever harsh chemicals you have around for that purpose. (IMG:style_emoticons/default/dry.gif) All that is left is seal the end with a thin bead of sealant, and place your cover on, torque down the cover. I have not gone there as I will be taking the trans apart further after cleaning up the outside. This is the basics on how to convert to FWD transaxle for a 914 or other mid-engine car. When you add it into the car, don't forget to add extra trans fluid to make up for the lack of central diff, and the other parts you removed. |
Lo-Fi Version | Time is now: 4th May 2024 - 06:59 AM |
