Signal Single Orange 74 EG33 Swap, Gone but not forgotten |
914forme |
Sep 25 2013, 07:47 PM
Okay this is the car in all its glory ugly as heck, but hey its an auto-x car. (IMG:style_emoticons/default/new_shocked.gif) This one is from my first season of auto-x with this car.
Heres what it looks like today. Made it even uglier (IMG:style_emoticons/default/barf.gif) Here is the goal, I can sketch ideas, but I can not draw at the level of others on this forum. Thank you 914 Visulizer. and my black pen. Now if I could find a good front view. And the flares are not on the car since I'm not using GT Flares. But you get the general idea. |
914forme |
May 20 2014, 07:14 PM
Rotisseri has been complete (IMG:style_emoticons/default/welder.gif)
I used a set of 914 Trailing arms for the rotational bearings, and found that they worked a little to well. So I had to create an indexing wheel to keep the chassis from rotating. I have the suspension removed on one side, so it will go to that side with out issue, stupid gravity. So how does a CSOB build an indexing wheel. With a 914-4 rear brake rotor of course. Next I figured I would have to find the level spot then figure out the angles do some math (IMG:style_emoticons/default/idea.gif) Until I remembered I have this. Then I drilled in a hole for a hardened guide. it is 5/16" ID, slight over 1/2" OD, and well a 15/32" hole, and a press and well I now have my fixture to hold the pin. After that grabbed my tight quarters drill and drilled my first hole with the bar level. Drill a bunch of holes, using the angle finder, and adding 22.5 degrees to each rotation. In reality it was easier than that, the degree finder is marked at 45 and 90, I just had to find 22.5 and 67.5. I used a clamp to hold it in position whileI drilled. It can be off just a little bit, It won't matter. And the final result. This was a huge step forward, allowed me to remove the chassis from my lift. I was then albe to get the SVX donor up on the lift, and start draining fluid prepping it for engine removal. Yes forward progress! |
dan_the _body_guy |
May 20 2014, 07:34 PM
Newbie Group: Members Posts: 28 Joined: 1-April 14 From: cleveland ohio Member No.: 17,185 Region Association: None |
Rotisseri has been complete (IMG:style_emoticons/default/welder.gif) I used a set of 914 Trailing arms for the rotational bearings, and found that they worked a little to well. So I had to create an indexing wheel to keep the chassis from rotating. I have the suspension removed on one side, so it will go to that side with out issue, stupid gravity. So how does a CSOB build an indexing wheel. With a 914-4 rear brake rotor of course. Next I figured I would have to find the level spot then figure out the angles do some math (IMG:style_emoticons/default/idea.gif) Until I remembered I have this. Then I drilled in a hole for a hardened guide. it is 5/16" ID, slight over 1/2" OD, and well a 15/32" hole, and a press and well I now have my fixture to hold the pin. After that grabbed my tight quarters drill and drilled my first hole with the bar level. Drill a bunch of holes, using the angle finder, and adding 22.5 degrees to each rotation. In reality it was easier than that, the degree finder is marked at 45 and 90, I just had to find 22.5 and 67.5. I used a clamp to hold it in position whileI drilled. It can be off just a little bit, It won't matter. And the final result. This was a huge step forward, allowed me to remove the chassis from my lift. I was then albe to get the SVX donor up on the lift, and start draining fluid prepping it for engine removal. Yes forward progress! thats a bit overkill but awesome at the same time (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/pray.gif) |
Lo-Fi Version | Time is now: 4th May 2024 - 01:10 PM |
