Signal Single Orange 74 EG33 Swap, Gone but not forgotten |
914forme |
Sep 25 2013, 07:47 PM
Okay this is the car in all its glory ugly as heck, but hey its an auto-x car. (IMG:style_emoticons/default/new_shocked.gif) This one is from my first season of auto-x with this car.
Heres what it looks like today. Made it even uglier (IMG:style_emoticons/default/barf.gif) Here is the goal, I can sketch ideas, but I can not draw at the level of others on this forum. Thank you 914 Visulizer. and my black pen. Now if I could find a good front view. And the flares are not on the car since I'm not using GT Flares. But you get the general idea. |
Chris H. |
Feb 23 2015, 07:45 AM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Yeah re: the RMW intake...the part I don't get is how they attached the rubber tubes that connect to the throttle body to their metal intake piece and made it air tight....they must have a serious lip on them or something...or maybe they are a one-piece mold. I've searched on ebay and at home improvement stores for something similar, no dice. You could probably just go with PVC pieces and use a rubber piece to connect between them and the throttle bodies, or go with 90 degree silicone pieces that would bend downward and allow you more room (use 1.5" BTW NOT 1.75 as it measures or it's not tight enough). Then you could connect with PVC or a custom box of some kind. It would be nice if we could convert the throttle body to a single hole. How cool would that be???
BTW you really helped me out by telling me about that whole cruise control removal thing. I can cap that off and flip my manifold around. I was hating how my setup encroached on the whole trunk. I also think the way I had the cruise hose set up with my custom intake was incorrect, causing an intermittent stall issue. So (IMG:style_emoticons/default/beerchug.gif) . |
Lo-Fi Version | Time is now: 4th May 2024 - 08:08 AM |
