Sold - Early 911 column & switches, 914-6 clone components |
Harpo |
Sep 26 2013, 05:25 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
sold
I have all of the components to make a 914/6 clone steering column. Including the following: early 911 column, turn signal switch, wiper switch, ignition switch w/bezel and clam shell. You will have to supply your own 914 steering column mounting plate. I cant very the functionality of the wiper & turn signal switch. You will have to grind/cut off the 911 mounting brackets and weld on the 914 brkt. $225 shipped CUSA |
Lo-Fi Version | Time is now: 18th May 2024 - 04:09 PM |
