3.6 questions |
3.6 questions |
914mikee100 |
Sep 30 2013, 12:13 PM
Newbie Group: Members Posts: 42 Joined: 20-July 12 From: Utah Member No.: 14,702 Region Association: None |
My project has now advanced to the point that I can concentrate on the engine. I am pulling the distributors for belt replacement and vent kit installation, pulled the injectors for ultrasound, ordered new sparg plug wires and plugs and caps, and it looks like I will need to get new valve cover gaskets. Other than a new main oil seal when i put the conversion flywheel on, is there anything else I should be looking for? Should I replace the crank sensor and O2 sensor or do they usually survive the transplant? This rubber is ripped. Do I just replace it with a plastic block off plate? |
Lo-Fi Version | Time is now: 18th May 2024 - 02:22 PM |
