Click to view attachmentClick to view attachmentClick to view attachment
My project has now advanced to the point that I can concentrate on the engine. I am pulling the distributors for belt replacement and vent kit installation, pulled the injectors for ultrasound, ordered new sparg plug wires and plugs and caps, and it looks like I will need to get new valve cover gaskets. Other than a new main oil seal when i put the conversion flywheel on, is there anything else I should be looking for? Should I replace the crank sensor and O2 sensor or do they usually survive the transplant? This rubber is ripped. Do I just replace it with a plastic block off plate?Click to view attachment
