MrHyde |
Senior Member ![]() ![]() ![]() Group: Members Posts: 525 Joined: 13-October 10 From: Ontario, Canada Member No.: 12,268 Region Association: None ![]() |
I have a couple gremlins I'm trying to sort out and thought I would post it up here...
Most of everything is working just fine, headlights/motors are working much better than they did in the parts car. I imagine thats because theres actual metal around the ground points.. (IMG:style_emoticons/default/biggrin.gif) Anyways heres what I got 1: Turn signals.. with headlights off left and right turn signals work just fine as do the 4-ways. With headlights on only the left turn signal works. right does nothing. no click, nothing. 2: trunk light and license plate lights are getting no power. This is coming off of fuse 7 along with the gauge lights which are working just fine and dimming when the knob is turned. I think this one might be a simple wire broken but I'm not sure yet. All I know is that I have no power when checked at the trunk light and ground.. |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,196 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
1- Could be the flasher relay. Not sure exactly how you'd test it, though. (IMG:style_emoticons/default/sad.gif)
2- There is a gray wire that goes through the main wiring harness and powers the engine bay light/rear trunk light and the license plate lights. In 74+ cars, it is hooked to the black/blue wire that powers the center console instrument lights. The connection is a little different in 73 and earlier cars, I think. Check connectivity on that wire. You may find it bundled up alongside the main harness in the center tunnel. What year is this 914? --DD |
MrHyde |
The harness is from my 73 parts car. There is a grey wire that comes off of fuse 7 along with the black/blue wire. The wires at the trunk and license plate are also grey.
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
#1 is a bad ground. With the lights off, the turn signals are pulling ground through the parking lamp. Lights on, ground goes away. This could also be caused by a bad lamp socket, pulling ground through the parking lamp. Check the front and rear lamp sockets first. Then clean the ground connections.
MrHyde |
All the ground connections were cleaned back to bare metal with new nuts on the ground studs too. I notices that the bulbs the selfs are corroded. I'll clean the lamp sockets tomorrow and try again
MrHyde |
Turn signals fixed. (IMG:style_emoticons/default/biggrin.gif)
I went around the car and double checked the ground points. and everything was clean and tight. So I started pulling the light bulbs and checking the sockets for corrosion and loose wires at the lamps. I found two things. 1: The right side turn signal was only a single filiment bulb when it should be a double. Changed the bulb and bingo, the signals work when the headlights/parking lights are on. 2: I also noticed that the brake/marker lights in the back were flashing (dimly) along with the left turn signal. Also the front left marker light was flashing and it shouldn't be. turns out I was looking at the tail lamp upside down or something when I hooked it up and had the ground and one other wire switched. switched them back and all is good now. Now I'm working on running a new line for the trunk light/license plate lights. The wire itself is broken/frayed near the trunk light. |
MrHyde |
New light ran for the trunk light and license plate bulbs.. everything works now. :-)
Lo-Fi Version | Time is now: 8th July 2025 - 10:58 AM |
