911/01 Transmission, Pull clutch Transmission that allows the use of stock 3.0 flywheel |
proto31 |
Oct 1 2013, 09:39 PM
Member Group: Members Posts: 413 Joined: 2-February 06 From: Costa Mesa, CA. Member No.: 5,515 Region Association: None |
SOLD (IMG:style_emoticons/default/smile.gif) This transmission came from a 1971 911 with 20k documented miles. The transmission was opened up and inspected, everything was perfect, re-sealed with new seal kit. Perfect for a 3.0 conversion, you can bolt this straight up to a stock 3.0 without modification. The pull clutch is a big improvement over the standard 914 pulley clutch, same install just use the clutch cable from a 1975 911. A 914 tail cone was fitted along with a side shift consul. Include the clutch fork and a good used throughout bearing for the clutch. Gearing- O - GA - O - V - ZA. asking $1,400
Blue6 |
Oct 3 2013, 08:49 PM
Senior Member Group: Members Posts: 1,035 Joined: 3-October 13 From: SoCal Member No.: 16,470 Region Association: Southern California |
Im interested in your tranny. Can u give me a call or send a number to get in touch with u. Have some questions. Dave. (562) 244-9102. Thanx
This transmission came from a 1971 911 with 20k documented miles. The transmission was opened up and inspected, everything was perfect, re-sealed with new seal kit. Perfect for a 3.0 conversion, you can bolt this straight up to a stock 3.0 without modification. The pull clutch is a big improvement over the standard 914 pulley clutch, same install just use the clutch cable from a 1975 911. A 914 tail cone was fitted along with a side shift consul. Include the clutch fork and a good used throughout bearing for the clutch. Gearing- O - GA - O - V - ZA. asking $1,400 (IMG:style_emoticons/default/piratenanner.gif) |
proto31 |
Oct 3 2013, 09:05 PM
PM sent (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 19th May 2024 - 03:45 AM |
