SOLD This transmission came from a 1971 911 with 20k documented miles. The transmission was opened up and inspected, everything was perfect, re-sealed with new seal kit. Perfect for a 3.0 conversion, you can bolt this straight up to a stock 3.0 without modification. The pull clutch is a big improvement over the standard 914 pulley clutch, same install just use the clutch cable from a 1975 911. A 914 tail cone was fitted along with a side shift consul. Include the clutch fork and a good used throughout bearing for the clutch. Gearing- O - GA - O - V - ZA. asking $1,400
