I can't wait to step on my clutch |
airsix |
May 24 2003, 02:56 PM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
Today's menu includes resurfaced flywheel, new seal, new kep stage II clutch w/ all fresh new hardware, and...... (Drum roll)
NO MORE STRETCHING/BREAKING CABLE/TUBE BS!!!!!!! (IMG:style_emoticons/default/biggrin.gif) Alright ladies, show's over. Back to work. -Ben M. Attached image(s) |
Aaron Cox |
May 24 2003, 04:58 PM
hydraulic clutch? way cool! how/where are you going to plumb it?
airsix |
May 24 2003, 06:29 PM
QUOTE(acox914 @ May 24 2003, 02:58 PM) hydraulic clutch? way cool! how/where are you going to plumb it? Hard-line goes right up the clutch tube. It's the perfect fit - just like it was made for it. MC is an aluminum Tilton (Brad's suggestion). Flex line to bridge from firewall to engine mount bar is a brake flex hose. Piece-o-cake. I love it when a plan comes together. Oops, almost forgot - 2psi residual presure valve to prevent drainback & spongy feeling. (IMG:style_emoticons/default/wink.gif) Total project cost was about the same as 2 clutch cables, so I figure if it lasts 5 years it'll have paid for its self (in addition to the pleasure of not having to adjust a stinking cable every month). -Ben M. |
Qarl |
May 24 2003, 06:45 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Keep us posted on the rest of the install details. And take/post pictures!
Regards, |
Gint |
May 24 2003, 07:52 PM
Mike Ginter Group: Admin Posts: 16,066 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Nice Ben. What are you using for a master cylinder? Where is it mounted?
Aaron Cox |
May 24 2003, 09:52 PM
QUOTE(Gint @ May 24 2003, 05:52 PM) Nice Ben. What are you using for a master cylinder? Where is it mounted? QUOTE MC is an aluminum Tilton (Brad's suggestion). problem solved (IMG:style_emoticons/default/wink.gif) |
Lawrence |
May 25 2003, 07:41 AM
Sound like it could be a really easy kit to put together... I hope you can take pictures of the install of the MC and hard lines.
-Rusty |
Gint |
May 25 2003, 08:23 AM
Like I said, where/how did you mount the MC?
Brad Roberts |
May 25 2003, 10:39 AM
Gint,
You mount it right next to the other MC. Flip the clevis over for the stock clutch cable and use it to push on the new MC threaded shaft for the clutch. Great job Ben (IMG:style_emoticons/default/clap56.gif) We are getting ready to do this on 930 converted 914. I typically use Neal... but the CNC is a tad shorter. I like it. B |
Bleyseng |
May 25 2003, 11:32 AM
Brad, post some pics as this looks like a killer mod to do. I am tired of fighting the clutch cable!
Geoff |
Gint |
I need pics!!! (IMG:style_emoticons/default/icon13.gif)
Bleyseng |
May 25 2003, 11:37 AM
How about using a clutch mc off a RX7? Nice and small design.
Geoff |
Brad Roberts |
May 25 2003, 11:52 AM
The Tilton/Neal/CNC MC's have a two bolt setup almost identical to the stock MC. You drill two holes..weld a thin scab plate to the flat wall area ..and mount it next to the stock MC. I use a second brake resovoir for the fluid.
Make that 3 holes.. 2 bolt holes and one BIG one for the MC itself. B |
May 25 2003, 11:54 AM
QUOTE(airsix @ May 24 2003, 04:29 PM) ...(in addition to the pleasure of not having to adjust a stinking cable every month). Heh... Nope, you get to substitute the joy of bleeding the clutch hydraulic system, and flushing the system every other year.... (IMG:style_emoticons/default/rolleyes.gif) I think I might prefer the hydraulic throw-out bearing (!!!) that Wevo has. Don't know if they've got one for the 901, but there was one for the 915! Kewl stuff. --DD |
Bleyseng |
May 25 2003, 11:58 AM
The Mazda one has a built in resevoir that sits on it. I have one laying around. I was toying with installing it but hadn't come up with the solution at the other end.
I thought WEVO had one for the 901? Geoff |
Brad Roberts |
May 25 2003, 12:04 PM
I dont think there would be enough room under there for the resovoir.. you know how hard it is to getbthe lines in the stock MC (no room)
B |
airsix |
May 25 2003, 04:46 PM
QUOTE(Dave_Darling @ May 25 2003, 09:54 AM) I think I might prefer the hydraulic throw-out bearing (!!!) that Wevo has. Don't know if they've got one for the 901, but there was one for the 915! Kewl stuff. --DD Yeah, I'd love the WEVO too, but $750 was about $650 over my target buget. (I'm sure it is a very well designed and built system) -Ben M. |
aufaber |
May 25 2003, 05:51 PM
Member Group: Members Posts: 190 Joined: 7-April 03 From: Huntington Beach, CA Member No.: 525 |
(IMG:http://www.earlyapex.net/images/tranny/MVC-294F.JPG)
Looks a lot like mine (IMG:style_emoticons/default/biggrin.gif) Works great, i used all wilwood bits. Pretty much the same thing though. I went with hard line all the way back except for some braided at the master and slave. I have since switched to braided from the firewall back since I realy didn't like how unsupported the hardline was hanging out there. -Aaron G. |
airsix |
May 25 2003, 06:59 PM
QUOTE Looks a lot like mine :D (snip) -Aaron G. Nice! I like it better than mine - your mount has the slave in better alignment with the fork. I think tonight I might go out and fab a new mount like yours. Thanks for posting the pic. -Ben M. |
914Timo |
May 26 2003, 12:02 AM
******* Group: Members Posts: 743 Joined: 13-January 03 From: Finland Member No.: 137 Region Association: Europe |
Very nice, but like Gint and others I would like to see pics about the MC. I am not sure if I understood all Brad explaned..... (IMG:style_emoticons/default/huh.gif)
Lo-Fi Version | Time is now: 26th April 2024 - 01:46 AM |
