FS 1973 Porsche 914 - San Antonio TX |
senator914 |
Oct 3 2013, 08:57 PM
I'm new here ... Group: Members Posts: 0 Joined: 7-September 13 From: San Antonio Member No.: 16,358 Region Association: None |
1973 Porsche 914 ($7,000 OBO)
2.4L Carb 175 ft-lbs of torque @ 3750 RPM and 135-150 Hp @ 5250 RPM Tangerine Racing Fuel Pump and Fuel Lines for Carburetors Package Rewired with new Hwy 64 kit and new fuse box Chassis stiffening kit Welded new battery tray Installed new stainless steel fuel lines stainless steel brake lines 911 front end 5 lug rear wheel hubs Added re-upholstered seats Center console w/gauges New re-upholstered arm rest Installed new headliner Installed new bright white/blue headlights Rear Porsche Reflector with electronic lock Pillar Gauge Selector Shaft Seal; Transmission Shift Rod Seal; 15x24x7mm Manual Trans Shifter Linkage; Set Screw for Shift Rod Coupling Engine/Motor Mount; Left/Right Manual Trans Shifter Linkage; Shift Coupler Bushing Set (Set of 2); Polygraphite Transmission Overhaul Seal Kit Speedometer Cable Differential Oil Seal; Left/Right Output Seal; 45x68x10mm Wheel Bearing; Rear Left/Right Sealed Bearing;; 42x75x37mm CV Joint Bolt; 8x45mm Hex Porsche 914 rear trunk spring rollers New set of 2 Porsche Aluminium Floor Mat Emblem 914 Lots of extras parts (A/C Unit, Aluminum Foot board and mat, 912 transmission, etc.) New engine: 2.4L Carb 175 ft-lbs of torque @ 3750 RPM and 135-150 Hp @ 5250 RPM Fully bead blasted and repainted sheet metal, accessories, and engine case Cleaned, inspected, and line bored Dual Relief case New AA 104mm Big bore Euro style Flat top Hypertuenic Aluminum P/Cs, ~8.2:1 CR 2.0L 71mm stroke STD Forged Crankshaft cleaned and polished Scat C35 profile cam, cam gear, & Lube a lobe solid lifters Scat 20011 High Rev valve springs Fully Rebuilt and flycut #021 casting 4 stud Porsche Heads New dual 44mm Empi HPMX carburetion system with linkage, intakes, and air cleaners New Mahle STD Rod bearings New Mahle .020”/STD Main bearings New Mahle STD Cam bearings Freshly turned 215mm Flywheel Full Victor Reinz Gasket set All New crankshaft seals New Contitech Alternator belt New Engine tin sheet metal screws New Bosch spark plug wires New Autolite spark plugs New 2.0L 009 electronic Distributor New Cap, Rotor New Compu-fire Super Coil New Bosch oil filter New 1.5 deep oil sump kit Additional oil cooler "Pickup preferred but willing to ship if you pay for the service" |
senator914 |
Oct 3 2013, 10:58 PM
senator914 |
Oct 3 2013, 11:02 PM
Attached thumbnail(s) |
Mike Bellis |
Oct 4 2013, 08:22 AM
Some assembly required??? (IMG:style_emoticons/default/confused24.gif)
senator914 |
Oct 4 2013, 06:10 PM
It was a restoration project, so there is still some work needed. Depending on how far you want to go with the restoration will determine what's needed to get it up and running. The fuel tank needs to be reconnected, upholster the interior, reconnect the seats, get 5 lug pattern wheels with tires, reconnect the master cylinder. I wanted to get a high performance muffler for the new engine. Here are some things that were done as well as part of the restoration. Removed all the rust by soda blasting. Applied anti-rust compound. Rewired the complete car with up to date wiring and new fuse box. Welded the trailer arm stiffening kit with new bushings onto trailer arms. |
senator914 |
Oct 9 2013, 05:44 AM
Price Update: $7,000
Evil914 |
Oct 9 2013, 08:15 PM
Newbie Group: Members Posts: 46 Joined: 25-October 10 From: mineral wells,texas Member No.: 12,309 Region Association: Southwest Region |
I like it!!! (IMG:style_emoticons/default/piratenanner.gif)
jbyron |
Oct 10 2013, 03:08 PM
Jamie Group: Members Posts: 128 Joined: 17-July 07 From: Ballwin, MO Member No.: 7,916 Region Association: Upper MidWest |
What the pictures don't fully indicate: 1) is the engine installed in the car currently; 2) Are all body panels installed (e.g. the front trunk lid).
senator914 |
Oct 10 2013, 09:50 PM
FrogMut |
Oct 16 2013, 01:18 PM
Newbie Group: Members Posts: 14 Joined: 11-November 12 From: Silicon Valley Member No.: 15,135 Region Association: Northern California |
Flares are fiber or steel?
IGTARD |
Oct 17 2013, 01:40 AM
IGTARD Group: Members Posts: 27 Joined: 8-October 12 From: Left Coast Member No.: 15,013 Region Association: Southern California |
Sold? (IMG:style_emoticons/default/shades.gif) IGTARD
senator914 |
Oct 18 2013, 03:19 AM
senator914 |
Still available |
Evil914 |
Oct 19 2013, 08:45 PM
I wish mine was looking this good. (IMG:style_emoticons/default/biggrin.gif)
brooks944 |
Oct 24 2013, 02:51 PM
Member Group: Members Posts: 241 Joined: 5-September 10 From: Kingston, TN Member No.: 12,139 Region Association: South East States |
Beautiful, wheel pics?
Hoppie944s2 |
Oct 24 2013, 02:58 PM
Porschenut Group: Members Posts: 64 Joined: 7-July 13 From: New Jersey Member No.: 16,098 Region Association: North East States |
What do you think it would cost to ship to NJ as it had no wheels?
earossi |
Oct 25 2013, 06:17 AM
Member Group: Members Posts: 210 Joined: 8-December 11 From: Chicago, Il Member No.: 13,878 Region Association: Upper MidWest |
Sent you a PM.
senator914 |
Oct 26 2013, 03:05 AM
senator914 |
Oct 26 2013, 03:07 AM
What do you think it would cost to ship to NJ as it had no wheels? Send me a private message with the address where you want it shipped. I also think I can get some generic wheels or rims so you can roll it onto the trailer or truck bed. |
earossi |
Oct 27 2013, 06:10 AM
Sent you a PM.
Lo-Fi Version | Time is now: 17th May 2024 - 04:10 PM |
