Seeking 914-6 relay board diagram for conversion. |
914itis |
Oct 6 2013, 08:26 AM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
I need a diagram to alter the 914-6 pin connector on the ignition harness to work on a 4 relay board
SLITS |
Oct 6 2013, 09:17 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
The 911/914-6 engine harness is a 14 pin connector. The 914/4 is a 12 pin connector. Won't quite work .. use a /4 engine harness and relay board and match function of the wires. I have diagrams at my office that I used. I'll see if I can get to them Monday.
Bad /6 wiring diagram Also, Andy (socalandy here) had a colorized one blown up so we could trace all of his wires. He might have the file on his computer. |
914itis |
Oct 6 2013, 09:32 AM
Thanks,
That was my request. I have the diagram / functions for the 4 board, I need the six pins function to match it up and modify. |
Eric_Shea |
Oct 6 2013, 09:44 AM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Get a later model alternator and ditch the board.
mepstein |
Oct 6 2013, 10:01 AM
914-6 GT in waiting Group: Members Posts: 19,256 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Get a later model alternator and ditch the board. (IMG:style_emoticons/default/agree.gif) sell the early alternator and ditch the board altogether. |
914itis |
Oct 6 2013, 10:11 AM
Get a later model alternator and ditch the board. (IMG:style_emoticons/default/agree.gif) sell the early alternator and ditch the board altogether. A later alternator will solve the voltage regulator issue, since the alternator has a built in regulator. I will still need to alter the pins on the harness whether it is via the board or direct connection. With that say, I will need a diagram or wire functions to match up the connections for the other components such as gauges, coil and tach. Am I correct? |
SLITS |
Oct 6 2013, 10:13 AM
You don't have to ditch the alternator for a newer one. As stated before, the alt plug on a /4 or /6 will plug directly into the VR. Mine is mounted on the wheelhouse where the battery used to be.
AND You can wire the engine harness directly into the main harness with a matching 14 pin male plug ... no relay board needed. AND While the colors are different on the wires, you can match function at the main body harness. Like I said, the notes are in my office and I can get them Monday. Images at 11! (IMG:style_emoticons/default/laugh.gif) Oh, I printed the 911 wiring diagrams off the Bird site and traced function. |
914itis |
Oct 6 2013, 10:21 AM
You don't have to ditch the alternator for a newer one. As stated before, the alt plug on a /4 or /6 will plug directly into the VR. Mine is mounted on the wheelhouse where the battery used to be. AND You can wire the engine harness directly into the main harness with a matching 14 pin male plug ... no relay board needed. AND While the colors are different on the wires, you can match function at the main body harness. Like I said, the notes are in my office and I can get them Monday. Images at 11! (IMG:style_emoticons/default/laugh.gif) Oh, I printed the 911 wiring diagrams off the Bird site and traced function. Thanks slits, Now can you recommend a VR? |
McMark |
Oct 6 2013, 11:29 AM
Bosch. (IMG:style_emoticons/default/wink.gif)
914itis |
Oct 11 2013, 08:28 PM
Thanks again Ron,
I also found this helpful diagram, I figure, I would post I here. Hope it can be of use for others. All of the wires locations in this diagram are accurate, except for the number 1 which is for the battery light, not the oil pressure switch. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 7th May 2024 - 06:14 PM |
