| CptTripps |
Jan 21 2014, 10:04 PM
:: Punch and Pie :: ![]() ![]() ![]() ![]() Group: Members Posts: 3,586 Joined: 26-December 04 From: Tuscaloosa, AL and Akron, OH Member No.: 3,342 Region Association: Upper MidWest |
Nice pillow!
| 76-914 |
Jan 21 2014, 10:35 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,988 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
IIRC, I tweaked the opening w/ a small crescent so that the opening is offset then they drop right in. After that straighten the opening back in line. Does that make sense? If not I'll shoot a photo. The next snag on that shifter is the 8mm stud. You need to grind it off and weld in a 1/4" stud for the heim joint. Clearances get tight between the shifting mechanisms and you may need to file the head of a bold down. Or use clevis pins for more clearance. And that pillow is a great comfort to my ancient old ass. (IMG:style_emoticons/default/biggrin.gif)
| ruby914 |
Jan 21 2014, 11:04 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
Does that make sense? If not I'll shoot a photo. The next snag on that shifter is the 8mm stud. You need to grind it off and weld in a 1/4" stud for the heim joint. Clearances get tight between the shifting mechanisms and you may need to file the head of a bold down. Or you could bend the mechanisms to the left some. (IMG:style_emoticons/default/biggrin.gif) I would of put a photo over at NARP but didn't have a place to put it (IMG:style_emoticons/default/lol-2.gif) This is what I came up with. I did have the same interference. one other thing that helped me is moving the pivot mount on the shift shaft up a little. I moved it up and down and bent the shaft forward and back more than once looking for the best feel and location. Moving the pivot up gives you a shorter shift stroke. this can also be changed by the rear linkage. The spring on the left is my reverse lock out. It keeps naturally in 2nd and 3rd position. A little resistance to 1st and reverse. I also had to cut open the cable slots and relocate them forward or aft for some reason. The riser is offset and tilted to the driver and up in the front. And yes, I had a cushion too. (IMG:style_emoticons/default/beerchug.gif) Attached image(s)
| IanJ |
Jan 22 2014, 04:04 PM
Member ![]() ![]() Group: Members Posts: 90 Joined: 28-December 05 From: Perth, Western Australia Member No.: 5,327 Region Association: Australia and New Zealand |
Ruby is your shift from an earlier MR2 (AW11)and the others are the later models (SW20)?
In the pics they look like different base plates. |
| rnellums |
Jan 22 2014, 04:14 PM
Professional Enthusiast ![]() ![]() ![]() Group: Members Posts: 1,673 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
JimKelley's shifter looks just like mine, our of a first gen MR2.
| ruby914 |
Jan 22 2014, 06:06 PM
I have no idea. I did a lot of cutting and bending. That's how it is now.
Honestly I don't recall. Now that I look at others, I may have made a completely new base plate out of 4" tube? I'm getting old. (IMG:style_emoticons/default/slits.gif) Ruby is your shift from an earlier MR2 (AW11)and the others are the later models (SW20)? In the pics they look like different base plates. |
| effutuo101 |
Jan 29 2014, 02:26 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,738 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
| CptTripps |
Jan 29 2014, 07:46 PM
He's close...
| 914forme |
Jan 30 2014, 10:11 PM
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,899 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None
II'm ready, Ian, you can aded one to my shipment (IMG:style_emoticons/default/piratenanner.gif)
| IM101 |
Feb 2 2014, 10:48 PM
Member ![]() ![]() Group: Members Posts: 264 Joined: 9-November 10 From: Boise Idaho Member No.: 12,367 Region Association: Pacific Northwest |
| Chris H. |
Feb 3 2014, 06:20 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,108 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest
Great news!
| effutuo101 |
Feb 3 2014, 10:53 AM
cool! excited.
| rnellums |
Feb 3 2014, 10:57 AM
Looks like it's about time to blow my paycheck on conversion parts!
| edwin |
Feb 3 2014, 04:39 PM
Member ![]() ![]() Group: Members Posts: 321 Joined: 20-May 09 From: Australia Member No.: 10,384 Region Association: Australia and New Zealand |
Are you able to produce something that neat for the 901 box
I was never a fan of bending and twisting the cables so your bell crank system looks fantastic Cheers Edwin |
| IM101 |
Feb 3 2014, 07:52 PM
Well I am planning on building a system for the 901 side shift but a bell crank with that setup might b a bit more tricky to pull off... Then again really need to sit down and look at it before I know for sure.
| ruby914 |
Feb 3 2014, 08:59 PM
Well I am planning on building a system for the 901 side shift but a bell crank with that setup might b a bit more tricky to pull off... Then again really need to sit down and look at it before I know for sure. Ian, I saw a cable shift folder on my laptop at home. It had Catia files. Not sure what is in there, they may give you some ideas, I'll take a look when I get home. It is hard to see but I used somewhat of a bellcrank system. This is from NARP. Mike Attached image(s)
| ruby914 |
Feb 4 2014, 03:04 AM
Well, the name of the folder is Cable tail shift.
I had this on the car until I broke first gear. I didn't make a cad file for the side shift but it works about the same way. Bell crank operates a brass or nylon, pivoting and sliding block that pushes and pulls the shift shaft in and out. Why is that photo a download? (IMG:style_emoticons/default/confused24.gif) Attached File(s)
Number of downloads: 151 |
| CptTripps |
Feb 4 2014, 04:30 AM
Why is that photo a download? (IMG:style_emoticons/default/confused24.gif) Windows Bitmap images can't be displayed by browsers. (Never have) They're the digital equilivent of Leaded Gasoline. |
| jimkelly |
Feb 4 2014, 05:29 AM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
here is ruby914 bmp as a jpg
Well, the name of the folder is Cable tail shift. I had this on the car until I broke first gear. I didn't make a cad file for the side shift but it works about the same way. Bell crank operates a brass or nylon, pivoting and sliding block that pushes and pulls the shift shaft in and out. Why is that photo a download? (IMG:style_emoticons/default/confused24.gif) Attached image(s)
| effutuo101 |
Feb 7 2014, 10:44 AM
Once I have half shafts and shifting in, I can start on my exhaust. Anybody want to go halves on a exhaust cut out? they come in pairs.... http://quicktimeperformance.com/QTEC/ |
Lo-Fi Version | Time is now: 28th October 2026 - 11:36 PM |
