> Won't start, used fuel pump vs aftermarket pump?
stefs914
post Oct 9 2013, 10:52 AM
I finally got all my ignition parts in new battery wires plugs cap rotor condenser. Resealed the gas tank with the por-15 kit drained and clean all the old fuel lines changes oil and went to start it and its getting zero fuel to the carbs. I don't hear any electrical noise from the fuel punp when I turn the key to acc and I'm also not getting any juice to the plug at the top not unless my volt meter is broke.
So I guess my question is, is do I try and get new fuses and see if that changes anything? Trace the wires and try to find a short? Or buy either a replacement pump an aftermarket pump?
Thanks in advance for any advice.
stefs914   Won't start, used fuel pump vs aftermarket pump?   Oct 9 2013, 10:52 AM
SLITS   Where did you wire the power to your fuel pump fr...   Oct 9 2013, 11:11 AM
stefs914   Where did you wire the power to your fuel pump f...   Oct 9 2013, 01:59 PM
Mblizzard   For me, I dislike tracing electrical problems asso...   Oct 9 2013, 01:09 PM
stefs914   For me, I dislike tracing electrical problems ass...   Oct 9 2013, 02:07 PM
stefs914   If it is the fuel pump what options do I have for ...   Oct 9 2013, 02:21 PM
timothy_nd28   If you replace the fuel pump with a new one, it st...   Oct 9 2013, 02:26 PM
SLITS   If it is the original wiring and you switched to c...   Oct 9 2013, 04:14 PM
SirAndy   If it is the original wiring and you switched to c...   Oct 9 2013, 04:28 PM
stefs914   The fuel pump is located directly underneath of th...   Oct 9 2013, 05:10 PM
SLITS   From the pics, they probably pulled power from the...   Oct 9 2013, 06:29 PM
bandjoey   That is an evil noisy aftermarket pump. Look at a ...   Oct 10 2013, 12:30 PM
rhodyguy   when you turn the key to the point when the dash/i...   Oct 11 2013, 10:04 AM
stefs914   when you turn the key to the point when the dash/...   Oct 11 2013, 05:25 PM
stefs914   when you turn the key to the point when the dash/...   Oct 15 2013, 08:55 PM
SLITS   No fuel pump near the filler. The facet is the on...   Oct 11 2013, 10:24 PM
stefs914   No fuel pump near the filler. The facet is the o...   Oct 11 2013, 11:15 PM
- Lo-Fi Version Time is now: 2nd July 2025 - 02:01 PM
