Opps, i did it again...taking more things apart :), "split" da' case tonight...oh no !!!! |
Mueller |
May 25 2003, 01:03 AM
Yep, my simple broken exhaust stud from last year has now turned from just replacing the heads to a full on overhaul/rebuild.....
I reached the point of no return when I cracked open the case tonight.... Things on my To Do list now; Balance rotating assembly, lighten flywheel and pressure plate, install HD oil pump and pressure relief springs, intall ARP thru-case studs and ARP head studs, install "Turbo" grind cam and new lifters..... (higher lift cam) |
Brad Roberts |
May 25 2003, 01:06 AM
Should'nt you be polishing a turd this evening for the Show and Shine tomorrow ??
B |
Mueller |
May 25 2003, 01:15 AM
I washed the car and that's it....I don't do the "show car thing"
Now that I think of it, i still have "cone" marks on the side of the car from last weeks auto-x (IMG:style_emoticons/default/MDB2.gif) ...oh well (IMG:style_emoticons/default/smile.gif) |
Lawrence |
May 25 2003, 07:34 AM
Mike,
I'm going to drop the engine out of the /6 this summer to fix some oil leaks and clean everything up. I'm worried that I'll develop Dirk Wright's Disease, and end up with a pile of engine parts (and no engine). For what it will cost to do a comprehensive rebuild, I could pick up another engine. Since I really don't want to upgrade brakes, etc... a 3.0 or larger is probably out. Choices, choices... (IMG:style_emoticons/default/smile.gif) -Rusty |
need4speed |
May 25 2003, 02:48 PM
Member Group: Members Posts: 339 Joined: 11-April 03 From: Arroyo Grande, CA Member No.: 564 |
QUOTE(Lawrence @ May 25 2003, 05:34 AM) .... fix some oil leaks ..... If you do that, it will no longer be a Porsche. . . (IMG:style_emoticons/default/rolleyes.gif) |
Brad Roberts |
May 25 2003, 02:49 PM
A 3.0 is fine with stock brakes.. just step up to a more agrressive brake pad.
B |
Joe Bob |
May 25 2003, 04:26 PM
QUOTE(Lawrence @ May 25 2003, 05:34 AM) Mike, I'm going to drop the engine out of the /6 this summer to fix some oil leaks and clean everything up. I'm worried that I'll develop Dirk Wright's Disease, and end up with a pile of engine parts (and no engine). For what it will cost to do a comprehensive rebuild, I could pick up another engine. Since I really don't want to upgrade brakes, etc... a 3.0 or larger is probably out. Choices, choices... (IMG:style_emoticons/default/smile.gif) -Rusty Build up a big four banger....I hear those 914s also came with them..... (IMG:style_emoticons/default/blink.gif) |
Lawrence |
May 25 2003, 08:46 PM
914s came with 4-cylinder engines?
Whoa... were they "real Porsches"? (IMG:style_emoticons/default/mueba.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 07:42 PM |
