Yep, my simple broken exhaust stud from last year has now turned from just replacing the heads to a full on overhaul/rebuild.....
I reached the point of no return when I cracked open the case tonight....
Things on my To Do list now;
Balance rotating assembly,
lighten flywheel and pressure plate,
install HD oil pump and pressure relief springs,
intall ARP thru-case studs and ARP head studs,
install "Turbo" grind cam and new lifters.....
(higher lift cam)
