Dash pictures, dash pics |
cal914 |
Oct 12 2013, 01:35 PM
Member Group: Members Posts: 319 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None |
Looking for some pictures of the dash trim when it goes round the steering wheel cowel
thanks |
1970 Neun vierzehn |
Oct 13 2013, 06:00 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
I am not sure if this is what you are looking for....this is from a 1970 /4.
Paul Attached thumbnail(s) |
Pat Garvey |
Oct 14 2013, 07:25 PM
Looking for some pictures of the dash trim when it goes round the steering wheel cowel thanks Attached are pics of my '72. The dash trim is one piece from the left until the radio area. Apparently the trim was applied prior to installation of the steering wheel and plastic dash cowl. I don't know if the one-piece unit is still available, and I've seen several instances where the material was cut and pasted above the cowl. Hope this helps. Pat (IMG:style_emoticons/default/pat.gif) Attached image(s) |
cal914 |
Oct 15 2013, 01:48 PM
Looking for some pictures of the dash trim when it goes round the steering wheel cowel thanks Attached are pics of my '72. The dash trim is one piece from the left until the radio area. Apparently the trim was applied prior to installation of the steering wheel and plastic dash cowl. I don't know if the one-piece unit is still available, and I've seen several instances where the material was cut and pasted above the cowl. Hope this helps. Pat (IMG:style_emoticons/default/pat.gif) thanks very much that's perfect |
Lo-Fi Version | Time is now: 4th May 2024 - 08:57 AM |
