| veekry9 |
Sep 19 2014, 07:11 AM
OldMember ![]() ![]() ![]() ![]() Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
| veekry9 |
Sep 19 2014, 08:03 AM
Side view with cam tower exposed showing lifter-block registers and seats. A custom barrel to carry a roller lifter can be fabricated to seat in the existing bore. (Edit:10/21/14) The stud spacing appears to be wide enough to accommodate an 90mm bore cylinder. Visible cylinder bore is 75mm,so perhaps as much as 90mm(+15mm) Anyone out there have real specifications of the head stud spacing? (as resolved from drawing,102mm bcd) http://www.914world.com/bbs2/index.php?sho...22522&st=98 edit:an 80mm(+8mm) stroke would yield 4.07 L,an increase of 1.5L . Aircooled V8 hemispherical head 16 V pushrod alloy engine. What's not to like?The crank is likely forged as the diesel manufacturing requires them. All around a decent small V8 with great potential,just needs some modern tech applied to them. / (edit:11/10/15) Have a look at these few vids. https://www.youtube.com/results?search_quer...gine&page=1 / (edit:08/06/16): http://retrorides.proboards.com/thread/148...a-sport-v8-pics / (edit:08/08/16): The numbers here are very close,so,a maximum bore diameter of ~90mm. The cast iron lifter bore bodies are seen attached to the cam tower.Custom versions made to carry roller lifters would fit nicely. At the bottom,one of the oil coolers is seated on it's seal flanges,the temperature sender at the top of the stud. The distributor barrel is at the right. (IMG:style_emoticons/default/smile.gif) / |
| veekry9 |
Sep 20 2014, 05:23 AM
Isdera Erator GTE,Eberhard Shulz.
I even like his first off. There was a yewtube of it being thrashed through the black forest,driver's view.(now removed) https://www.youtube.com/watch?v=MyYgYho43mQ https://www.youtube.com/watch?v=khxgb2EP5ac https://www.youtube.com/watch?v=f2AMLaTDXAo (edit:07/08/16) https://www.google.ca/search?q=Isdera+Erato...QkJBa0Q_AUIBigB https://www.google.ca/search?q=isdera+imper...UoeAFAQ_AUIBigB / (Edit:08/14/16): |
| veekry9 |
Sep 21 2014, 11:23 AM
| veekry9 |
Sep 21 2014, 11:31 AM
http://www.fiero.nl/forum/Forum3/HTML/000091-53.html Looking for a new dash? Some ideas from the custom Fiero world Immaculate work by Amida 10/10 |
| veekry9 |
Sep 21 2014, 09:19 PM
https://www.youtube.com/watch?v=oZZXKIDqv2c https://www.youtube.com/watch?v=v39Z8oFpbbE https://www.youtube.com/watch?v=ClRqT2uoXTo...cuI_ZXOUvqXEFKA the stuffing of an aircooled v8 into a light sports car.. https://www.youtube.com/watch?v=x3zW9uaiVNk |
| veekry9 |
Sep 29 2014, 04:55 AM
| veekry9 |
Sep 29 2014, 05:41 AM
| veekry9 |
Sep 29 2014, 09:25 AM
in fact the axle passes below the crankshaft middle main bearing journal perhaps as little as 25-30mm. With the sump pan removed,you can see the main bearing cap that carries the axle. Note chain driven oilpump and filter mount,starter to the right.Aluminum bearing caps are cross-bolted,the block rails extended far below the crank CL,perhaps suitable to carry structural loads. Mounting the block in front of 901 TX seems possible although the uneeded portions of the casting create a 5-7 kg weight penalty,easily removed. bare Y-block,differential cast integrally.Front(Rear) fan casting mounts on right,cam drive. the stash at the wreckers,found at this link: Obviously unaware of the huge demand for these parts. http://www.lhotkanet.cz/mirror/aek4470.finalnet.cz/ / (edit:07/31/16): A unique design modification,to allow the use of the engine in a mid configuration. The original driveshaft is used to drive a cv joint where the differential formerly was. A new casting is made to carry the diff,raised from the factory position,dropping the CG,and pan to ride height. The engine is run with a crank and cam position trigger,for coil on twin plug ignition,no dizzy. A conversion to chain drive for the cams,and vvt takes less room at the drive end of the block. A hyvo chain to drive a shaft going forward to a front diff,can make for a awd car. (IMG:style_emoticons/default/idea.gif) http://retrorides.proboards.com/thread/148...a-sport-v8-pics / |
| Mike Bellis |
Sep 29 2014, 09:19 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Since the axle is too far forward for a 914, you should... Weld the diff like a spool, mount the engine transversly, install a AWD drivetrain and make the first air cooled V8 AWD 914. The transmission diff will act as the transfer case.
| veekry9 |
Sep 30 2014, 12:11 AM
The original intent of the designer was to package an entire powerplant and drivetrain into a light compact discrete component.A twin engine 4x4 for example would only require installing an engine package as there are no auxilary peripherals needed,being aircooled.An engine over the axle is a design suitable for front drive and or rear drive and is suitable for adaptation to other applications.Mounting the engine in place of a 914's 4 cylinder,you gain displacement and a few pounds that theoretically at least,is easily shed.I can find no faults in the design and a few unique solutions that simplify the manufacture and maintenance of it.The engine has no inherent problems with pulling studs out of the block or bearing failures,as it's a robust ribbed casting.
here's an example with a turbo mounted,likely with stock components internally. This is the Tatra-700-EFI: |
| veekry9 |
Oct 5 2014, 04:24 PM
This is really cute,but somehow the taillights and bumper look too modern for the bug roofline.Perhaps a little Ghia,? Stuffing an early '63 914 with a 2.5 to 4.4 Litre V8 of an aircooled design has to be OK. Turns out there may be as few as 10 Tatra V8 engines in North America. There may be a HotRodder in the EU who may wish to give it a go. The 4-cam 613 could run with the heads swapped for a hot-V. Convenient for turbocharging and intercooling plumbing. |
| veekry9 |
Oct 5 2014, 07:35 PM
| veekry9 |
Oct 5 2014, 08:12 PM
Like this Outlaw POLO 356,the '63 914 has a rounded,curved house. If the hips pinch in at the tail,and the roof-line blends into the vertical face below the trunk-line,a nice Ghia like curvature will result.Voluptuous. Add a little sponson and the two lamp treatment. Very 60's retro. |
| veekry9 |
Oct 19 2014, 12:49 AM
| veekry9 |
Oct 19 2014, 08:10 AM
| veekry9 |
Oct 20 2014, 03:01 PM
| veekry9 |
Oct 20 2014, 04:56 PM
Liquid cooled? Requires a rad in front. A very sophisticated look also from the 924/944/968 product lines. Well done.I even like the color. Raised brand logo on rocker is a nice custom touch. edit:Nov 15/14 found this> http://members.rennlist.com/bluethunder/coverpag.htm |
| veekry9 |
Oct 20 2014, 08:15 PM
Chrome Yellow bright pearl.Now with accent stripe in Lime. WB stretch,18" ATS + Michelin RR sticky.A nice flat TurboSix to motivate. Rusty 914 + Honda crx roof,hammered into a shape that looks '90s. The Honda roof a tribute to the iconic 911 curve at a fraction of the cost. Another look for the CRX roofline transmogrification. Honda did a nice rendition of the tapered b-glass. Fits on a Fiero too,transforming the early windscreen slope to a more modern look,911-ish. I recall Chuck Beck(edit:Randy) did a 914 > GT1 custom roof that I liked.Without all the accoutrements of wings n poorly shaped flares,running boards and air dams it looks ok.Quite reserved but sporty enough to turn heads even with standard power.Really brings the 914 shape into the '90s. |
| veekry9 |
Oct 20 2014, 09:30 PM
Lo-Fi Version | Time is now: 16th February 2026 - 03:40 PM |
