| veekry9 |
Oct 19 2014, 12:49 AM
OldMember ![]() ![]() ![]() ![]() Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
| veekry9 |
Oct 19 2014, 08:10 AM
| veekry9 |
Oct 20 2014, 03:01 PM
| veekry9 |
Oct 20 2014, 04:56 PM
Liquid cooled? Requires a rad in front. A very sophisticated look also from the 924/944/968 product lines. Well done.I even like the color. Raised brand logo on rocker is a nice custom touch. edit:Nov 15/14 found this> http://members.rennlist.com/bluethunder/coverpag.htm |
| veekry9 |
Oct 20 2014, 08:15 PM
Chrome Yellow bright pearl.Now with accent stripe in Lime. WB stretch,18" ATS + Michelin RR sticky.A nice flat TurboSix to motivate. Rusty 914 + Honda crx roof,hammered into a shape that looks '90s. The Honda roof a tribute to the iconic 911 curve at a fraction of the cost. Another look for the CRX roofline transmogrification. Honda did a nice rendition of the tapered b-glass. Fits on a Fiero too,transforming the early windscreen slope to a more modern look,911-ish. I recall Chuck Beck(edit:Randy) did a 914 > GT1 custom roof that I liked.Without all the accoutrements of wings n poorly shaped flares,running boards and air dams it looks ok.Quite reserved but sporty enough to turn heads even with standard power.Really brings the 914 shape into the '90s. |
| veekry9 |
Oct 20 2014, 09:30 PM
| r_towle |
Oct 20 2014, 09:31 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
You are bouncing around a lot.
What was that v8 aircooled motor? What years, what countries was it produced? |
| Dave_Darling |
Oct 20 2014, 09:47 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,364 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
The Tatra aircooled V8 was built starting in the mid-30s. It was in several models, and went up into late 90s. There may have been diesel truck motors that went later than that.
Early: http://en.wikipedia.org/wiki/Tatra_77 Late: http://en.wikipedia.org/wiki/Tatra_700 --DD |
| veekry9 |
Oct 20 2014, 10:35 PM
It would be complicated to import the Tatra V8,whether the early SOHC, pushrod or the later quadcam.
There is some unrealized potential in these sturdy alloy engines,400hp has been bandied about as the number. The block casting of the 613/700 has that unique integral differential housing,placing the crank 1-1.5 in above the axle. A very nice design in every way,unappreciated in markets in which it never appeared. The engine sitting atop the axle in a 914 would,I'm sure,ruin any handling features of the car. Placing it mid however,you would have a light powerful aircooled V8 with the added bonus of an all Teutonic 914. The small displacement and stroke makes possible the use of a flat crank and cams plus the heads can be turned for a hot vee exhaust layout. After all,an aircooled V8 design would enhance the awesome factor of any 914 build. The difficult part is having a few shipped to your garage at a reasonable cost or any price,just to begin work. The sound of a 308 GT4 emanating from a 914 would be worth it all,the work being large in dimension. Be the first on the pit row with a twin turbo version to catch the latemodel of your choice. (edit:07/06/16) Zingback to the start of the Tatra dialog. http://www.914world.com/bbs2/index.php?sho...22522&st=91 / |
| veekry9 |
Oct 22 2014, 01:26 PM
| veekry9 |
Oct 22 2014, 01:32 PM
| veekry9 |
Oct 23 2014, 11:16 AM
| ClayPerrine |
Oct 23 2014, 11:20 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,568 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
I have absolutely 0 skills at photoshop, but maybe somebody would like to photoshop a 1973 Boxster for us? Take a 73 914, and graft the front end of a 73 911 targa onto it.
I want to build one in real life, and put a Boxster emblem on the back. |
| veekry9 |
Oct 23 2014, 12:31 PM
More like an impressionist painting in oil than anything else.
Incredible that it's stock below the beltline. Looks very modern,telling how far ahead the design of the 914 was in '67. |
| veekry9 |
Oct 24 2014, 07:15 AM
Now,stuffing an engine of great power into a 914 chassis mandates some reinforcement,namely a cage structure of Nascar proportion. A set of tires to handle the high speeds and the wheels to hold them. Not a single original panel. Longer,wider wheelbase,3"stretch behind the rear axle. Door lengthened,carries cage bars. Waisted rocker in alloy/ss. Nose rubber 2" longer,lower,so's the bumper,and wider. Cow catcher air dam for the racecar look,has a rubber lower lip. Siglamps are moved with the outer fender skin and sloped back to match the nose rubber,so they're longer. Pop-ups are moved out with the fender,still work. A 2-Tone anodized/painted wheel center for a modicum of polish. A 914 Carrera GT?Still a 914,wings optional. |
| veekry9 |
Oct 24 2014, 10:36 AM
| dlkawashima |
Oct 24 2014, 11:10 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
I have absolutely 0 skills at photoshop, but maybe somebody would like to photoshop a 1973 Boxster for us? Take a 73 914, and graft the front end of a 73 911 targa onto it. I want to build one in real life, and put a Boxster emblem on the back. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.porschemania.it-12234-1414170632.1.jpg) |
| veekry9 |
Oct 24 2014, 12:09 PM
What's not to like?
A wash ,some cosmetic rust repair and a respray in a color of favour. Add a wing to grace the rear deck and balance the look of a racer. He's added some airscoops above the rear fender as a bonus. A 914 modified to a level similar to the GT1's,twenty years later,might satisfy the need for speed. We now have the cnc technology that was quite expensive at the time,available at reasonable cost. https://www.youtube.com/watch?v=ECQv95kN-38 https://www.youtube.com/watch?v=pq1eP3NSd6Q / |
| veekry9 |
Oct 27 2014, 08:39 PM
https://www.youtube.com/watch?v=z8XqNR5i2B8 wow,smooth.8:17.(edit:less grandstand straight gap-7sec=8.10) https://www.google.ca/maps/place/N%C3%BCrbu...b73ca589a?hl=en Quote: Someone close to the car, "isderaimperator", came by to explain why the car smoked, and how it has the larger, later 6.0 liter Merc motor. The car in the video it the number 14 of 17 (series I. From Series II there where made 13 pieces). The car was built in 1988 and has a old AMG 6.0-32v engine (modified 5.0l Mercedes V8) instead of the 560 V8 which came as the standard engine. The smoke in the vid: Nothing dangerous, just a restoration mistake from 2006. On the side of the copilot, there is an air intake in the wheelhouse, above the front tyre, for the air-condition. …and a little bit to much material. Due to the weight of the copilot and the massive compression in that downhill left corner "fuchsröhre" with around 120mph, the left front tyre had contact with the air intake, and smoke (plastic, tyre) came into the air condition system for a second. On the road it never happened. After that trackday the air intake was restored properly by Isdera with the right dimensions. The track was cold and partly wet. The driver is not an Isdera test driver, but the owner, with racing experience (2012 Champion of the German Hankook Cup- and touring car championship). Unquote https://www.youtube.com/watch?v=GjiqXPy3bRw |
| veekry9 |
Oct 29 2014, 12:31 PM
918 in the morning mist.
https://www.youtube.com/watch?v=rJEeM5FZcGQ Also knows the track well. 956 6:37 Derek Bell https://www.youtube.com/watch?v=aSkEO1VnhaI 20,832 m 6:11.13 Porsche 956 Gr. C Stefan Bellof 28 May 1983 n/a Pole-position for 1983 1000k Sports Car race |
Lo-Fi Version | Time is now: 5th October 2026 - 12:22 PM |
