| veekry9 |
Sep 25 2015, 02:20 PM
OldMember ![]() ![]() ![]() ![]() Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
(IMG:style_emoticons/default/lol-2.gif)
(IMG:style_emoticons/default/bootyshake.gif) yah,them chems really constipated me a few weeks ago,so,I was like full of kot. (IMG:style_emoticons/default/icon8.gif) |
| veekry9 |
Sep 25 2015, 02:26 PM
![]() Yeah I drew it first,then I made them.Simple. When I was younger,working the clay. A repertoire of excellence. An abundance of these are available in South America,go get some. (IMG:style_emoticons/default/biggrin.gif) |
| veekry9 |
Sep 25 2015, 02:41 PM
"the Red Fox has a long nose" The snout is no longer than the factory baby bumpers. An aero tray to direct high pressure to the rear,avoiding the (pressure) differential below the racer. I noted this day that the builder has installed bench upholstery,likely to gain more headroom with the helmet.I might like the same treatment to shed some kilos. A righthooker for the Cooper nose job,in extreme proportion. In blue,a simply formed variation to punch the air,reducing the apparent flat plate area. Make faster with the same power. (IMG:style_emoticons/default/evilgrin.gif) |
| veekry9 |
Sep 25 2015, 03:06 PM
A chalkboard was used to express the idea. (edit:01/21/16) As per drawing,5L-V12 Longitudinal. The actual Countach we drooled on at the show in TO,I recalled the fitment of the frunk,so I 'repaired' it in Gimp.I even like the color,new in 69. A longitudinal mid. (IMG:style_emoticons/default/biggrin.gif) |
| veekry9 |
Sep 30 2015, 08:47 AM
| veekry9 |
Sep 30 2015, 08:50 AM
A forlorn 924/944 resurrected as a mid,a difficult transition. Looks neat tho. (IMG:style_emoticons/default/smile.gif) Checking the ads for a cheep 944,engineless. (edit:11/24/15) Outside of the box,a real Porsche.Turbo'd n Chilled (IMG:style_emoticons/default/biggrin.gif) It is however,still front engine! http://rennlist.com/forums/924-931-944-951...oled-boxer.html http://gatebil.no/gallery_photo/ http://www.performanceforums.com/forums/sh...nt-to-do/page10 |
| Dave_Darling |
Sep 30 2015, 12:38 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,364 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
| veekry9 |
Oct 1 2015, 04:03 PM
Ya,I put it there to be visible at the viewpoint of the drawing,so the fan was visible,the injector covers are merely decorative. While I was working on an 8,a 12 came up.An x configuration,solves a couple of problems and creates others.Seems workable tho. (720/6)/2=60*.An unusual layout made more viable by the 15* VR6.(Quote:You can't do ....). No overnight sensation,this is a long term project with plenty of challenges.Like how do you incorporate a vvt layout with only 4 cams? / (edit:05/26/16) New metallurgy allows significant weight loss,thermal conductivity improved. A set of cylinders of minimum mass. (IMG:style_emoticons/default/biggrin.gif) / |
| veekry9 |
Oct 7 2015, 12:27 PM
Pretty Pix of the computer model of the X12. Used sbc dimensions for the rods,etc.This is a huge displacement,4.25 bore x 3 stroke. 4.06" Bore X 2.5" Stroke=427"/7L What it will sound like.. (IMG:style_emoticons/default/evilgrin.gif) http://audacityteam.org/download/
935_12_05.mp3 ( 1.14mb )
Number of downloads: 238A nice tone for a phone or alarm,wake to the sounds of a 935-12. the original file:
935.MP3 ( 1.14mb )
Number of downloads: 185 |
| sixnotfour |
Oct 7 2015, 01:49 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,378 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
80's build...... (IMG:style_emoticons/default/driving.gif)
| veekry9 |
Oct 7 2015, 02:14 PM
Sure,this is at the root of the Martian9 body.
One of the drawbacks is the aero drag,can't install the heavy door bars and have windows that move. Certainly a much simpler approach,one that has worked well in the past and looks acceptable now. My endeavor is the smooth-sided with the massive scoops and intercoolers,maintaining the cg of a mid. The effect of the weight of the rads up front can be tested by simply filling a pail of water and swinging it about at 140mph. The other purpose of the large (TR)side scoops is to fill the rear of the targa,reducing induced drag,with the fan. The major surgery and workload doesn't put me off at all,as some of my work related jobs took 8+ months to complete(turbines). The doorskins are fair game for my plans,and may be subject to a material change,to make more light.Patient,critical design. The only criticism I have is the spoiler,which,of course,is not effective at all,reminiscent of ricer additions to compact sedans. A more radical change to the concept of adding great power,calls for a serious rollcage and the addition of lightweight components. A watercooled engine requires I include radiators,intercoolers,hoses,pumps and fans.By confining the added mass to the central regions of the wheelbase,the cg can be maintained,instead of the 'dumbell' additions at each end,with their larger moments of inertia. https://www.google.ca/search?q=moment+of+in...2rbQgLfgnaAM%3A / |
| veekry9 |
Oct 13 2015, 02:36 PM
| veekry9 |
Oct 13 2015, 02:51 PM
Add some reflections Appears to be a pair of 60* V6's sharing a common 6 pin crank. More accurately, a pair of sixes 60* apart,meeting an even fire order. Right side view,a simple shoebox head,4valve. ![]() Angular view,with case ribs and studs,head studs,Mbearing webs Some top views,showing the offsets of each bank,shorter than the v or flat arrangments. The short stroke and large Mbearing dia allows an ample pin overlap. |
| mgp4591 |
Oct 14 2015, 02:22 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,037 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region
At first I didn't know what to think of that body mod, but the more I saw of it over at Genes the more I liked it and if the money was here at the time it might have been mine! We researched the kit and never really found out whether it's a one-off or a kit you can still buy but with a little work it will look sharp! The lines are definitely there and it even suggests lines of the Carrera GT to a degree- have you done any research on it to find out where the parts came from? |
| sixnotfour |
Oct 14 2015, 04:38 AM
its a one off CA. 80's build.. running driving,,,914-6
| veekry9 |
Oct 15 2015, 10:28 AM
Some reading from the references therein.
LTU_EX_06099_SE.pdf ( 1.82mb )
Number of downloads: 832http://www.rotaryeng.net/Voyager-Eng.pdf t4201.pdf velaccdiag.pdf LTU-EX-06099-SE.pdf Mahindra 2 Wheelers - Piston Skirt profile Optimization to eliminate Scuffing and Seizure in a Water and Air Cooled gasoline engine using PISDYN_ForSharing.pdf 117_IJHE_January 2015.pdf Malpress_afmc_16_07.pdf 538-115.pdf 43662.pdf 20154060.pdf aerosim_ug.pdf AirCoolerdHotAir.pdf A-Theoretical-Model-For-Selection-Of-V-angle-And-Determination-Of-Firing-Order-For-Balancing-Of-V6-engine.pdf DEA.pdf definition-F02F.pdf e3-11-01-03.pdf energies-08-05866.pdf Engines.pdf Garrett_White_Paper_01_Water_Cooling.pdf httpwww_bg_utp_edu_plartjok32007jo20kones20200720no20320vol201420mitianiec.pdf IJHE 2013_Kewal.pdf lecture-7.pdf LiquidPiston-XMini-Specifications.pdf l-ring_effect.pdf ogst08082.pdf Princeton-CEFRC2.pdf qip-ice-25-cooling systems.pdf SAE010903.pdf Szilard_Engine.pdf YRJ-1992-IIII.pdf (IMG:style_emoticons/default/blink.gif) http://gibtecpistons.com/?page_id=81 Planning a blown engine? (edit:11/25/15)
PETRONAS_superbike_engine_case_study.pdf ( 457.77k )
Number of downloads: 393Worthwhile reading,even now,almost a decade later,just to be on the same page. http://www.eurospares.com/graphics/engine/...searcheable.pdf / |
| veekry9 |
Oct 22 2015, 03:46 PM
| mrfourteen |
Oct 22 2015, 05:19 PM
Member ![]() ![]() Group: Members Posts: 74 Joined: 1-November 13 From: Oregon out in the Mozarks Member No.: 16,596 Region Association: Pacific Northwest |
| veekry9 |
Oct 22 2015, 05:30 PM
Van engine?
The Pentastar. http://blog.caranddriver.com/chrysler-reve...-pentastar-v-6/ Available at your local wreckers. http://www.compositesworld.com/articles/hi...er-expectations https://www.google.ca/search?q=glass+filled...gA&dpr=1.75 / |
| veekry9 |
Nov 2 2015, 03:23 PM
Mostly stock components.VVT. (IMG:style_emoticons/default/dry.gif) An exercise in ic design,you know,like roll your own. (IMG:style_emoticons/default/biggrin.gif) An aircooled 12 cylinder to fit inside the 914 envelope,a proposal that the 917 engine cannot meet. Note the raised cam towers ala Julius Mackerle's Tatra.A vvt setup not available to the designers in '58-69. https://en.wikipedia.org/wiki/Julius_Mackerle Lightening up on the reciprocating parts and some elements from this decade makes for a viable -12. A liquid cooled set of heads makes a 4valve arrangement possible,reducing mass of the valves for a given area. A convenient feature is the proximity of the exhaust ports for a turboed variant,upping the ante for ultimate power levels of a Nurburgring endurance trackster. The above pix is a simple Corvair version limited by all of the original factors of that design. ![]() This is a 290 Cummins roller cam follower,cast. ref:http://www.flycorvair.com/delabruere.html |
Lo-Fi Version | Time is now: 5th October 2026 - 10:03 AM |
