New 914 owner. Hello, and a question about replacement bushings |
Corellian Corvette |
Oct 17 2013, 12:09 AM
Newbie Group: Members Posts: 9 Joined: 16-October 13 From: Woodinville, WA Member No.: 16,521 Region Association: None |
Evening everyone!
Just joined tonight, as I got my first Porsche (a 1973 1.7) last weekend. I've loved these since I was a kid, and although I have quite a few vintage muscle cars, I'm interested in exploring the world of European sports cars. The previous owner is a friend of mine, and he's an engineer and racer who has really brought back a nice original car. It has no rust, and he's taught himself the ins and outs of the fuel injection system and has the engine in perfect working order. Mechanically the car is perfect. The only negative of the car is that he recently installed front poly control arm bushings, and while the car handles well, the noise is unacceptable. Even he regretted it. So the only real change I need to make is to replace the front bushings. All the catalogs list either Poly or Graphite replacements. I'm not going to drive then car hard enough, or put enough miles on it, to get the benefit of poly. I would prefer comfortable ride and quiet so my wife will join me. Is there an OEM rubber bushing available that's completely quiet? Once that's done, perhaps someone can explain the confounding contraption called the heater controls. Thanks in advance! |
Oct 17 2013, 01:37 AM
Resident German Group: Admin Posts: 41,638 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Is there an OEM rubber bushing available that's completely quiet? Nope, no OEM rubber. Which is why there are several aftermarket solutions of different quality. Ok, let me take that back, if you contact Porsche you might actually still be able to get the original rubber bushings. Problem is, if so, they are firmly attached to a brand new a-arm! (IMG:style_emoticons/default/icon8.gif) PS: (IMG:style_emoticons/default/welcome.png) |
mskala |
Oct 17 2013, 05:48 AM
There is definitely a source of rubber that is not bonded to a new arm, I've seen a video of it. Will try to find it later. I have recently gone to Elephant Racing poly-bronze, which has been nice and quiet and easy to install.
jimkelly |
Oct 17 2013, 05:50 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
most anything you will need for your 914 can be gotten at
pelican or pmb http://www.pmbperformance.com/914suspension.html |
Jgilliam914 |
Oct 17 2013, 06:12 AM
914 Guru Group: Members Posts: 5,327 Joined: 30-July 12 From: Iowa / Florida Member No.: 14,732 Region Association: Upper MidWest |
(IMG:style_emoticons/default/welcome.png) Good advice so far
KELTY360 |
Oct 17 2013, 07:13 AM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
Can't believe I get to say this: (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
NORD |
Oct 17 2013, 09:02 AM
Senior Member Group: Members Posts: 1,505 Joined: 14-September 04 From: Lynden Washington Member No.: 2,756 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/welcome.png) For rubber front control arm bushings, contact Eric at PMB Performance. He is a vendor Here and a up front guy. You can also get rubber rear swing arm bushings. No sqweekkkkk. I redid mine, all OK. (IMG:style_emoticons/default/driving.gif) |
Matt Romanowski |
Oct 17 2013, 09:05 AM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
Elephant Racing has rubber control arm kits with the tools to install them.
shuie |
Oct 17 2013, 09:17 AM
Member Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
Try the URO brand stock style rubber or whatever Eric @ PMB Performance or Chuck @ Elephant Racing recommend for a street car. There are lots of threads here and videos on youtube that walk through the install process.
6freak |
Oct 17 2013, 11:13 AM
try some grease... (IMG:style_emoticons/default/confused24.gif) ...install zerks if not already in! ...worked for my polybroze squeak but grease wont help the harsh ride...just loose some PSI in the tires when the little women is along...welcome and injoy your new toy
(IMG:style_emoticons/default/smile.gif) |
green914 |
Oct 17 2013, 11:24 AM
Senior Member Group: Members Posts: 1,467 Joined: 29-March 11 From: Sacramento, California Member No.: 12,874 Region Association: Northern California |
mittelmotor |
Oct 17 2013, 11:50 AM
Member Group: Members Posts: 334 Joined: 21-May 12 From: SoCal Member No.: 14,464 Region Association: None |
I used Weltmeister "restoration" bushings that I bought at Paragon Products. They're a little bit firmer than the stock rubber bushings, but no squeaks whatsoever. If only I could get my targa top seals to be so quiet!
stefs914 |
Oct 17 2013, 04:19 PM
Newbie Group: Members Posts: 32 Joined: 27-April 13 From: lincoln ne Member No.: 15,812 Region Association: Upper MidWest |
ConeDodger |
Oct 17 2013, 04:41 PM
Apex killer! Group: Members Posts: 23,587 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Oct 17 2013, 11:50 PM
Thanks everyone! Pics will be forthcoming this weekend. I've been too busy driving it!
What is the consensus on adding zerk fittings? I was considering that. Can it be done on the car? Might be a good thing to try first before pulling the a-arms off again... After following the links I think I like the elephant racing ones. But racking the car and installing some zerks might be worth a step... |
Oct 18 2013, 06:24 AM
Is there an OEM rubber bushing available that's completely quiet? Nope, no OEM rubber. Which is why there are several aftermarket solutions of different quality. Ok, let me take that back, if you contact Porsche you might actually still be able to get the original rubber bushings. Problem is, if so, they are firmly attached to a brand new a-arm! (IMG:style_emoticons/default/icon8.gif) PS: (IMG:style_emoticons/default/welcome.png) Elephant has a stock, oem rubber solution. Front and back. It's on their website. |
DEC |
Oct 18 2013, 06:39 AM
Senior Member Group: Members Posts: 630 Joined: 10-November 05 From: Rehburg Member No.: 5,104 Region Association: Germany |
carr914 |
Oct 18 2013, 06:42 AM
Racer from Birth Group: Members Posts: 118,648 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
BillH has some FreeMotion Bushings FS in the Classifieds at a Very Good Price |
Cap'n Krusty |
Oct 18 2013, 08:52 AM
Thanks everyone! Pics will be forthcoming this weekend. I've been too busy driving it! What is the consensus on adding zerk fittings? I was considering that. Can it be done on the car? Might be a good thing to try first before pulling the a-arms off again... After following the links I think I like the elephant racing ones. But racking the car and installing some zerks might be worth a step... Rubber bushings and grease don't get along all that well ..................... The Cap'n |
Oct 18 2013, 11:17 AM
Elephant has a stock, oem rubber solution. Front and back. It's on their website. No, they don't. They have and i quote "OEM spec rubber replacements". They are neither stock nor OEM but they probably just as good as the originals were 40 years ago. (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 08:11 AM |
