Look what I did, Mega Jolt Light Jr. |
Dr Evil |
Dec 20 2004, 02:27 AM
I just assembled my DIS MJLJ OMFG. Now I gotta figure out how to use my computer to play with it, and how to get the sensor and wheel mated (Oh Mueller (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) ). It will be going on my /6 and I will document so others can copy.
chunger |
Dec 20 2004, 02:29 AM
Member Group: Members Posts: 409 Joined: 11-January 03 From: Albany, CA Member No.: 133 |
Dr Evil |
Dec 20 2004, 04:07 AM
I can assemble anything electronic, but I don't kow crap about computer programming. I have been goofing with this damn thing for the last few hours and I can't even find the damn java -jar mjlj_x.x.x.jar' to start the show. I am in way over my head on this prog4ramming thing. If I could only find a translator (computer to english) (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif)
gaz914 |
Dec 20 2004, 04:31 AM
Member Group: Members Posts: 67 Joined: 6-March 04 From: Sydney, Australia Member No.: 1,758 Region Association: None |
Coooooool! I just spent the last few days trying to work out what cars in OZ I can get EDIS parts off to do the same thing! I got the software going OK already (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Dr Evil |
Dec 20 2004, 05:01 AM
Dude,
I have spent the last three hours fooling with trying to getthe software up and running, but I am a complete novice so the posted directions are not understandable to me. Do you have a resource for how to assemble the folders and get them running. I need like; put this here, click this, see that, make it do this..etc. My head hurts....its 3am here, I quit for tonight. (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) Oh, welcome to the club Gaz! |
gaz914 |
Dec 20 2004, 06:10 AM
Hi Mike, thanks for the welcome.
OK, lets try some step-by-step (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) (I'm hoping you understand files and folders) Go to www.java.com. Click on the yellow rectangle (top right) which starts the software download. You should be asked if you wish to install "Java Plug-in 1.4.2_06" - say YES. Follow prompts, etc for the automated install. After the install (could take some time) you should have a directory called - "C:\ProgramFiles\Java\j2re1.4.2_06" Download the [Java Comm] 'zip' file from http://picasso.org/mjlj/?q=node/view/6 (click on the link and choose [SAVE]). A dialog should open up and just save the file anywhere (desktop is good). if you haven't already got WinZip, download from [HERE] Run WinZip and open the "Javacomm20-win32.zip" file you just downloaded and [extract] the files to "C:\ProgramFiles\Java" You should now have a sub-directory named "commapi". Open the "commapi" directory and find the "comm.jar" file. Copy (right click-copy) and paste (right click-paste) in the "C:\ProgramFiles\Java\j2re1.4.2_06\bin" directory. Open the "commapi" directory and find the "win32comm.dll" file. Copy (right click-copy) and paste (right click-paste) in the "C:\ProgramFiles\Java\j2re1.4.2_06\bin" directory. Open the "commapi" directory again and find the "javax.comm.properties" file. Copy (right click-copy) and paste (right click-paste) in the "C:\ProgramFiles\Java\j2re1.4.2_06\lib" directory. Make a directory (I used "C:\MJLJ"). Download the actual MJLJ software ("mjljTune2.0.3.jar") and save in that directory. Open the "commapi" directory again and find the "comm.jar" file. Copy (right click-copy) and paste (right click-paste) in the "C:\MJLJ" directory (or whatever you have used). Open the MJLJ directory and double click the "mjljTune2.0.3.jar" file and all should be (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) Just downloaded and installed as I typed this and works OK on our 2nd PC Hope that it works for you Mike. cheers GAZ |
Dr Evil |
Dec 20 2004, 10:40 AM
Thanks GAZ,
Well I got through most of the steps that you posted, but I have a few questions. 1. What is a directory? Is it just a file that I make at the given address i.e. C:\MJLJ. If so, I put all of the things in their perspective folder. 2. I noticed that the software is in a .zip format, not a .jar format. How do you switch the file type to .jar? I looked into this on the MJLJ web site and noticed others were having the same problem, but they knew how to change the name or what ever to rectify it. Thanks for all of your help. I think that I am close. Mike |
Dr Evil |
Dec 20 2004, 10:53 AM
I figured it out. I changed the program that opens it to javaw, and added.jar to the name. After clicking it it opened. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Thanks mate! Next problem: I have only USB ports and I have an adaptor. How do I get the program to use the USB instead of a serial port? I think that many were having this same problem and there may be some info on the web site. I know that they said to test using hyperterminal (?), no idea. |
Mueller |
Dec 20 2004, 11:01 AM
sure I can help you out, let me know how you want it mounted...with Dave Hunts method (which is pretty damn slick!!!! ) you need to cut a slot into the fan housing, not too sure if he made a template or not for the fan and the location of the missing tooth
for my install, the back side of the fan housing needs to be ground down a bit to clear the VR sensor Do you have a trigger wheel yet and the sensor? |
Aaron Cox |
Dec 20 2004, 11:04 AM
hes doing a six not a type4 (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Mueller |
Dec 20 2004, 11:26 AM
opps....my bad....I "forgot" about that other motor, LOL
I'm sure we can work something out, lemme know (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) |
gaz914 |
Dec 20 2004, 01:54 PM
Try some tips from [HERE] Hyperterminal can usually address more "ports" than some software, therefore if if you start Hyperterminal and 'connect' via the usb/serial port then, although you may not get anything 'useful', you should be able to see some sort of data from the MJLJ (characters on the screen). This 'proves' the cables, etc are correct. Not far now... |
Lo-Fi Version | Time is now: 19th May 2024 - 03:54 PM |
