QUOTE (Dr Evil @ Dec 20 2004, 12:27 AM) |
I just assembled my DIS MJLJ OMFG. Now I gotta figure out how to use my computer to play with it, and how to get the sensor and wheel mated (Oh Mueller ). It will be going on my /6 and I will document so others can copy. |
QUOTE (Mueller @ Dec 20 2004, 10:01 AM) |
sure I can help you out, let me know how you want it mounted...with Dave Hunts method (which is pretty damn slick!!!! ) you need to cut a slot into the fan housing, not too sure if he made a template or not for the fan and the location of the missing tooth for my install, the back side of the fan housing needs to be ground down a bit to clear the VR sensor Do you have a trigger wheel yet and the sensor? |
QUOTE (Dr Evil @ Dec 20 2004, 08:53 AM) |
I figured it out. I changed the program that opens it to javaw, and added.jar to the name. After clicking it it opened. Thanks mate! Next problem: I have only USB ports and I have an adaptor. How do I get the program to use the USB instead of a serial port? I think that many were having this same problem and there may be some info on the web site. I know that they said to test using hyperterminal (?), no idea. |
