What size fuel hose?, From rear firewall up to engine shelf |
boxsterfan |
Oct 19 2013, 02:11 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
My 1974 2.0L has SS fuel lines all the way back through the tunnel.
I have a leaking fuel line where it connects to the SS pieces going through the engine shelf. I was able to remove the leaking hose (has a crack near the end) and of course is a good idea to replace them anyways. What size is the hose supposed to be? Inner diameter? I thought it was 8mm but I am just unable to get that hose on there. Any tips for getting fuel hoses back on to SS lines? |
SLITS |
Oct 19 2013, 03:18 PM
SS is going to be 3/8" (9.5mm).
They used to be paired as 3/8"(9.5mm) supply and 5/16"(7.9mm) return. If they are the same size, they are probably 5/16". |
TheCabinetmaker |
Oct 19 2013, 03:57 PM
If it's 5/16 hard line, then 8mm should fit with a little lube and a bit of force
boxsterfan |
Oct 19 2013, 10:13 PM
Ended up being a 9.5MM (3/8"). No leaks now. Phew!!!
Cap'n Krusty |
Oct 19 2013, 10:38 PM
If it is 3/8, then you'll need the Porsche supplied adapter hose to step it down to 7.5mm at the fuel rail if you have FI. Clamping 3/8 hose down to 8mm is commonly known as a "fire starter" in the trade.
The Cap'n |
JawjaPorsche |
Oct 20 2013, 07:07 AM
Double post, sorry! (IMG:style_emoticons/default/smile.gif)
JawjaPorsche |
boxsterfan |
Oct 21 2013, 01:46 PM
I ended up using the 3/8" fuel hose with two (2) hose clamps on each end. On the end coming out of the firewall (9.5mm SS tube is my guess), the 3/8" fuel hose fit well and was clamped with two hose clamps. On the end that meets the SS tube going up through the engine bay (8mm SS tube from what I read here), I attached the 3/8" fuel hose but utilized two (2) smaller hose clamps that just barely fit around the 3/8" hose and was able to clamp it down tight. The first time I tried with the same size clamps as I utilized at the firewall connection and I got leakage everywhere (ala fire starter). As of now, it sounds like I should get the 9.5mm to 8mm step-down tube as it comes out of the firewall/tunnel? The fun never ends... |
Lo-Fi Version | Time is now: 16th May 2024 - 04:55 PM |
