Glove box lid removal? |
partwerks |
Oct 20 2013, 04:35 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Was going to re glue the edges of the material on the glove box lid, and so was going to take it off for better, access, and I have the two screws out, but before I rip into it further, not exactly sure how to get it out/off at this point?
PanelBilly |
Oct 20 2013, 04:50 PM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I'd try to re-glue the edges without removing it
Oct 20 2013, 06:57 PM
Take off the strap that holds the glove box and remove that first.
All from behind. Then the door goes out the back. |
pneuhyde |
Oct 21 2013, 12:06 AM
Member Group: Members Posts: 94 Joined: 24-February 05 From: San Leandro, Ca. Member No.: 3,654 Region Association: Pacific Northwest |
All good advise, just wish I hadn't learned it by trial and error YESTERDAY (IMG:style_emoticons/default/ohmy.gif)
But while we are on the subject, I am trying to go a little further and want to remove the padded dash top for replacement and it has been a real pain so far. I got the middle three nuts by removing the radio and standing on my head underneath the dash. Then OMG, the nuts in the corner of each end caused a last minute run to the parts store because I could not find my swivel adapter for my socket wrench and my fingers refused to kink and bend in the direction I told them to go. Now I have two roadblocks left. 1) I don't know how I will ever get some of the nuts started again and 2) It may not matter because it looks like there are at least two more nuts holding the dash top on. I know about them because I pulled my gage face plate out a little (with gages still attached) and I think there are nuts inside a piece of metal channel at the very back of this area, where my dash still seems to be attached. I have know idea what kind of socket wrench will fit inside the channel ? Any Ideas ? |
SLITS |
Oct 21 2013, 06:50 AM
#2 ... a thin open end wrench .. two nuts at the forward edge (windshield) of the instrument cluster hood.
Brian_Boss |
Oct 21 2013, 08:04 AM
Member Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 |
Given how much fun it is to get the springs back on (the ones on either side that hold the door open or closed), I would pull the door toward you as far as you can and do you gluing while hoping the springs stay attached.
Mblizzard |
Oct 21 2013, 09:35 AM
In the few dashes that I have removed I have found the nuts were not very tight. I used a long screw driver to start the nuts turning and it went pretty easy. Of course yours will be so tight that this suggestion will seem silly but try it just in case. I cussed and worked for an hour to get at one nut only to find it was lose!
pneuhyde |
Oct 21 2013, 10:42 PM
#2 ... a thin open end wrench .. two nuts at the forward edge (windshield) of the instrument cluster hood. Thanks. I did find a pic in an old thread that showed them but it was still a mystery what kind of a wrench would work. It also confirmed to drop the steering column for better access. Steve |
pneuhyde |
Oct 21 2013, 10:44 PM
In the few dashes that I have removed I have found the nuts were not very tight. I used a long screw driver to start the nuts turning and it went pretty easy. Of course yours will be so tight that this suggestion will seem silly but try it just in case. I cussed and worked for an hour to get at one nut only to find it was lose! Yes to not very tight, which did help and I did consider the screw driver and hammer approach. (IMG:style_emoticons/default/smile.gif) |
dlkawashima |
Oct 21 2013, 11:28 PM
914 Guru Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
Harbor Freight sells finger ratchets in a pack of 3. Not very good quality but good enough for a one-time job. Harbor also sells a small swivel head ratchet. At a bike store you can buy a thin cone wrench that will help get at those two hard to reach nuts behind the gauges.
As for the glove box, I would follow the advice previously offered and try to do the fix without removing the lid. Those springs are as bad as the two nuts behind the gauges in difficulty factor. |
Lo-Fi Version | Time is now: 16th May 2024 - 01:13 PM |
