Porsche 914 2.5 liter racing engine for sale, SOLD |
JDHursh |
Oct 21 2013, 11:25 AM
I'm new here ... Group: Members Posts: 0 Joined: 9-October 13 From: Winter Park, FL Member No.: 16,491 Region Association: South East States |
2.5 liter race motor with 35 hours
specs: 7R mag. case (shuffle pinned) twin plug crankfire ignition Carrillo con. rods Mahle pist./cyls. 10.3:1 CR counter balanced crank The motor needs: carbs. exhaust ignition (Electromotive) alternator/fan The engine last ran 1 1/2 years ago with no problems. Approx. horsepower 220-240 at the flywheel. The motor was built by Franz Blam in Atlanta. $5500 or obo |
brant |
Oct 21 2013, 11:57 AM
How many hours on it?
sixnotfour |
Oct 21 2013, 12:46 PM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
35hrs....
barefoot |
Oct 21 2013, 05:54 PM
Senior Member Group: Members Posts: 1,273 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
2.5 liter race motor with 35 hours specs: 7R mag. case (shuffle pinned) twin plug crankfire ignition Carrillo con. rods Mahle pist./cyls. 10.3:1 CR counter balanced crank The motor needs: carbs. exhaust ignition (Electromotive) alternator/fan The engine last ran 1 1/2 years ago with no problems. Approx. horsepower 220-240 at the flywheel. The motor was built by Franz Blam in Atlanta. $5500 or obo Is what' pictured all that's included, no fan/alternator or engine tin ?? |
jpnovak |
Oct 21 2013, 07:22 PM
They call me "Nanoman" Group: Members Posts: 231 Joined: 26-August 09 From: Austin TX Member No.: 10,736 Region Association: Southwest Region |
I have a few questions...
What cams? Dyno curves to show torque distribution? What is the redline run? What is the normal shift point? Trying to determine how much wear at 36 hours. I assume this is 66x90mm. Case work? Timeserts or Casesavers? Oil bypass mod done? Was the case line bored or shaved and resized? Port sizes? What were original heads? MFI ports? |
JDHursh |
Oct 21 2013, 08:18 PM
I have a few questions... What cams? Dyno curves to show torque distribution? What is the redline run? What is the normal shift point? Trying to determine how much wear at 36 hours. I assume this is 66x90mm. Case work? Timeserts or Casesavers? Oil bypass mod done? Was the case line bored or shaved and resized? Port sizes? What were original heads? MFI ports? The short honest answer is that I don't know. I am checking...I will post when I have the answer from the mechanic who did the work. Everything in the photo and description is what is included and what the engine needs; including engine tin. |
sixnotfour |
Oct 21 2013, 08:40 PM
Talk to eric shea about good used race engines...Franz Blam is one of the Best. Time and maintenance is the wild card..
JDHursh |
Oct 29 2013, 11:11 AM
JDHursh |
Oct 29 2013, 11:19 AM
I have a few questions... What cams? Dyno curves to show torque distribution? What is the redline run? What is the normal shift point? Trying to determine how much wear at 36 hours. I assume this is 66x90mm. Case work? Timeserts or Casesavers? Oil bypass mod done? Was the case line bored or shaved and resized? Port sizes? What were original heads? MFI ports? I can't speak to the cam or dyno...but I do know that it ran well and at 35 hours needs a refresh. No MFI ports. Normally when shuffle pinned it is bored, but I can't confirm that. The ports are 39 tapered to 35mm. All I can tell you is it's a good engine, Blum built and well maintained. I've not opened it up myself. And, being a 7R it's worth what I'm asking. I hope that helps. I would keep it, but I'm running a different car now and don't need an engine of this type (or the chassis I'm selling as well). |
JDHursh |
Nov 3 2013, 04:39 AM
The engine and chassis are now sold...package deal. Thanks everyone for your questions, interest and comments. Have a great day!
carr914 |
Nov 3 2013, 05:20 AM
Racer from Birth Group: Members Posts: 118,603 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Lo-Fi Version | Time is now: 15th May 2024 - 05:56 AM |
